Rule Machine repeat question…..
Say I have a rule with 4 triggers that when opened for 30 min. I want to play a message on my Zooz chime like close ‘X’ door where X is the door contact that triggered the rule. I want to repeat that message every 30 min. thereafter. I understand creating a rule to do this for 1 door. My question is if say door 1 is opened for 30 min and triggers the rule then I uses a repeat for 30 min until closed. If during that 30 min wait for door 1 to close, door 2 triggers the rule after being open for 30 min and plays the message for door 2 and starts a 30 min repeat for door 2. What happens to the repeat for door 1? Is it lost and only door 2 is now repeating or are there now two instances of the rule running and door 1 repeat will continue to run while door 2 repeat is running? If I put the repeat in an if then statement for that door and wait for that particular contact to close, will that continue to repeat if the rule is triggered by another door and then that repeat in it’s own conditional will run as well?
Like….
If door = door1
Repeat every 30 min until door1 is closed
Play chime for door1
End repeat
Else if door = door2
Repeat every 30 min until door2 is closed
Play chime for door2
End repeat
