A bit of info that might be useful for people experiencing lockups that can't be explained by Chromecast TTS or APIXU, or other community apps.
I have a C4 hub that had been locking up on almost a daily basis (red light, solid lock). I was puzzled, and followed along with this thread to see if any of the suggestions made sense with my configuration.
My hub was mounted in the same upstairs closet as my Media Server, a network switch, a pi or 2, a Hue Hub, and a Zwave Toolbox. The Hubitat, Hue and the Toolbox were all mounted vertically on the wall, spaced reasonably, but probably at least 6-12" apart.
The closet gets warm, and although I've never measured it, it's probably in excess of 85F.
Though this doesn't seem terribly hot, the Hubitat is passively cooled, and it seems that while the Hue Hub, Zwave Toolbox and Media Server were all content (or rather I have seen no ill effects), the Hubitat simply didn't like it.
On a whim, I moved it out of the closet and onto a table about 6' from where it was. Ambient is now in the low-mid 70s, and there is air movement due to a ceiling fan whenver the temp is above 72. This seems to have effectively eliminated my hub shutdowns. It's been up constantly for more than a week, with nary a glitch.
Perhaps not helpful in all cases, but it appears that the Hubitat C4 might be slightly temperature sensitive, and if you install it in an enclosed space with other forms of heat, it could result in lockups (and is probably not good for the lifespan of the Hub!).
It probably comes as no surprise that I'm reconsidering the location of the primary heat source (the MediaServer!).
For now, the Hubitat is staying out in the open!
S.
