I'd be interested to know if my Generic Zigbee Switch driver also work with that one. If you test it, let me know
It does. The only difference is that your driver starts with all plugs on, while the Aurora starts with all plugs off.
Btw, I tested also your illuminance driver, not very deeply indeed. It seems that if the illuminance variation is lower than the set minimum, the driver does'nt update last checkin date/time
Ok, nice, at least it is generic enough then
At least 30 minutes need to pass for a new checkin event to be recorded with that driver. All my drivers have a minimum, but what that is depends on the driver. Most are set to 30 minutes though. This is there to keep from recording too many events.
@markus so now I have not any excuse not to hack my previous wifi power strip with your tasmota driver .
I need to recover my dusted programmer ... and my only single neuron...
The power strip data are as following:
Data * endpointId: 01
- hasMultiEP: true
- application: 42
- softwareBuild:
- driver: v0.8.2.0720b
- inClusters: 0000,000A,0004,0005,0006
- outClusters: 0019
- model: TS0115
- isMultiEP: true
- manufacturer: _TYZB01_vkwryfdr
If you don't mind, could you give me what is printed when you press Get Info? The line about fingerprint.
fingerprint model:"TS0115", manufacturer:"_TYZB01_vkwryfdr", profileId:"0104", endpointId:"01", inClusters:"0000,000A,0004,0005,0006", outClusters:"0019", application:"42"
@markus I installed tasmota-hubitat in my old wifi tuya power strip (4 plugs+usb).
Which Module Type should I set the module in order to controll the 4 plugs independently ?
For something like that you would need to set a template correctly for all pins. Exactly what device is this? If there is a template on this site it would make it easier.
ok. with that template it works by now!
EDIT: good! so now I have 1+ fully local power strip. Thanks markus
@markus just a note:the main phisical switch is acting only on the latest plug (child device) , not on the others. Any advice?
Template changed to AOFO
In the parent device:
DEVICE CONFIGURATION= generic device
[SOLVED] the main button can switch on/off any single plug (1 to 5) with multiple tapping : 1 tapping for 1st plug, 2 rapid tapping for 2nd plug and so on.
