No, we are already below the minimum reliable geofence radius Google recommends. GPS and location detection on mobile isn't meant to be millimeter accurate.
Hi @patrick
Just some early feedback for you.
The app automatically switching to local or cloud dashboard is working great and a nice addition.
Why is there always a but.......
Unfortunately my geofence resized itself today. I must admit this had stopped happening so I'm not sure if it was 'just one of those gliches' or whether the root cause was addressed in the beta release but is not working.
Keep up the good work though.
I've not had any issues with devices dropping off, hub slowness etc. for weeks now.
Hhmm. Tempting fate I know.
Just thought I would look at my geofence again and once again it has increased in size with no interaction from me. Twice in one day.
I have the geofence set to around a radius of 220.
I noted this a few weeks ago. If you look at the Debug Information in the mobile app settings, I think you'll find the app is still respecting the geofence radius you set, just the image of the geofence is increasing.
While troubleshooting another issue tonight, I swear I saw a tiny side menu appear with access to not only the dashboards, but the rest of the Hubitat menu system. Couldn't get it to duplicate, however.
Is there a secret button? Did I lose my mind for a moment?
V 1.28 (Build 41)
I was playing around with local dashboards, put my phone down, came back 30 minutes later, and when the cloud dashboards switched to local, I had a fully functional "hybrid" app.
There is a much simpler way, just put a link to your main system up as a link tile. You can get a bit of Hubitat inception going on by opening up that same dashboard and repeat. My best was 4 layers deep.
Some feedback of an issue I have intermittently.. sometimes on app startup the splash screen will just keep reloading and goes into a loop. If I kill the app and restart, it then opens fine. I do not have to log back in or anything like that. Also, a suggestion - allow notifications to be viewed after you swipe them away from the notification bar. For example, I have it set to push a lock code usage notification which it does.. but once I swipe it away, there is no way to see it. Would be great to have a log of sorts to see them.
Another issue.. I have a rule set that when my phone enters the geofence the garage door should open. It only works if the app is in the foreground. so I pull into the geofence and nothing happens until I put the app in the foreground then it works like it should. Is there something I'm missing in the app?
