Is there a way to add an Amazon wifi thermostat to the device list? I'd like to control it from my dashboard.
Directly - no. However, since it's an Amazon device it should be compatible with Alexa so you could set up a virtual thermostat in HE and then use Alexa routines to coordinate.
No. However, the mounting plate used is the same as Honeywell's UWP. So you could replace the head unit with a Honeywell T6 Pro Z-Wave thermostat, which is Hubitat compatible.
I dont know how well this would work. Can you set the temp of a stat based on the temp from another stat in a routine? I have never tried but I always thought you could just do basic things like turn switches on and off and that was about it.
I did it at one point, but forget if I had to create a modified driver to cover things like that.
