Hi I have been trying to get TTS to work. Still having trouble getting it to work at all on my Echo Dot 4 gen after setting up Echo Speaks. My Nest Hub basically sounds like gibberish.
I understand that Hubitat TTS uses Amazon Polly. Ideally, I would like to use supported SSML tags for the both of the following use cases:
- Since I live in a bilingual house, I would like to be able to use the following code within HE
<lang xml:lang="is-IS">'Ég tala ekki íslenska?'</lang>
- I am trying to recreate Slacker Lab's Jarvis Home Assistant setup in HE, in particular, this code:
<*voice name=”Brian”>
<*Amazon:auto-breaths>
<*prosody rate=”fast”>Pardon me, lightning has been detected.
</prosody>
</amazon:auto-breaths>
<*/voice>
Is this possible in HE?
