OK, fix should be available. Anyone who is seeing the error when adding or editing a device trait should update to version 0.32.2.
seems to work
Package Manager found the update, i am installing a device and will test
Thanks a lot !!!
yep, it works !
Thanks !
by any chance, is there any way to see the sensor temperature on the google phone app ?
because for now, I only can ask verbally Google to give me the sensor temperature...
i'll continue trying stuff
anyhow, thanks a lot !
You can set the sensors to use the Google "Thermostat" device type and add a query-only Temperature Setting trait.
Works,
weirdly, i'm sure i tried it but with all the debug i did today... not sure of anything
this being said, your help is really appreciated !
thanks a lot
Just checking - there still isn't a way to convert motion notifications from the Nest Hello doorbell into something Hubitat can use is there?
No, this app only goes the other direction: it adds devices from Hubitat to Google Home. It cannot add devices from Google Home to Hubitat.
Thanks. Do you know anything that would?
New Release: 0.33.0
This release fixes the Camera Stream trait to work with Google's API changes and adds support for the Arm/Disarm trait. It also adds the ability for devices to query PIN codes from the device driver rather than having them configured directly in Google Home Community.
Big thanks to @lpakula for these new features
New Release: 0.34.0
This release adds the Sensor State trait to allow you to query various types of sensors such as CO, smoke, or leak sensors. Thanks to @lpakula for this one as well.
There was also a small patch, 0.33.1, earlier today which normalizes handling of temperatures so they always get rounded to one decimal digit.
I like this solution but 2 questions:
What is the flag to limit caching? Because the stream starts at the oldest cached .ts file
My Chromecast devices (Nvidia Shield or Nest Hub) do not seem to like the stream, and I end up with the same issue. I have a feeling it could be a resolution issue? I can't use the Hubitat app "Chromecast Integration (Beta)" Play Track to work. It just brings up a blank screen. If I use pychromecast in Python, it seems to work fine.
I'm trying to be able to use Hubitat to control streaming, rather than running a Python script on a BlueIris alert.
I have found an issue with the App with regards to using lock / unlock with pin codes. executeCommand_LockUnlock method passes in the codePosition after matching against a device PinCode. However, this then causes a failure as lock() and unlock() methods do not take the parameter codePosition. The solution to this is to replace the parameter codePosition with null. The Mfa still validates that the pin code matches. See code changes below.
@SuppressWarnings('UnusedPrivateMethod')
private executeCommand_LockUnlock(deviceInfo, command) {
def lockUnlockTrait = deviceInfo.deviceType.traits.LockUnlock
def checkValue
def codePosition
if (command.params.lock) {
codePosition = checkMfa(deviceInfo, "Lock", command)
checkValue = lockUnlockTrait.lockedValue
issueCommandWithCodePosition(deviceInfo, lockUnlockTrait.lockCommand, null, lockUnlockTrait.returnUserIndexToDevice)
//issueCommandWithCodePosition(deviceInfo, lockUnlockTrait.lockCommand, codePosition, lockUnlockTrait.returnUserIndexToDevice)
} else {
codePosition = checkMfa(deviceInfo, "Unlock", command)
checkValue = { it != lockUnlockTrait.lockedValue }
issueCommandWithCodePosition(deviceInfo, lockUnlockTrait.unlockCommand, null, lockUnlockTrait.returnUserIndexToDevice)
//issueCommandWithCodePosition(deviceInfo, lockUnlockTrait.unlockCommand, codePosition, lockUnlockTrait.returnUserIndexToDevice)
return [
(lockUnlockTrait.lockedUnlockedAttribute): checkValue,
isJammed: false,
isLocked: command.params.lock,
There's a setting that was added to the Lock/Unlock trait to control that. Disable the "Select to return the user index with the device command on a pincode match." toggle to prevent the app from trying to pass the PIN code index back to the driver. That's supposed to default to being off, but maybe something's not quite right if you have a Lock/Unlock trait from before it existed.
Perfect, thanks so much. That worked.
Now we just need to convince Google to add lock state and lock keypad in GHA so we do not have to use voice every time.
Are you sure it starts at the oldest? It will lag 15-30 seconds from real time with m3u8. It's just part of the spec that it needs to cache some stream before it can play.
What is the resolution of your source? Below is an image on what have set for my 3D printer camera which works fine on Nest hub and Nest Hub max (they each have different resolutions). One big one is you need to enable audio on your video stream in BI (even if the camera doesn't have it). Google expects a video+audio stream, or it will play nothing.
I was having issues with BI and a memory leak when using m3u8 so I switched to running ffmpeg to create the m3u8 stream, while fixing the resolution and adding blank audio. That's been working flawless for me for the other 8 cameras I mapped to Hubitat.
My God, you are a genius. I was trying every possible setting to figure out why Chromecast didn't like the m3u8 stream and it turned out it was the disabled audio channel in BlueIris....
As soon as I enabled that it worked!
I don't seem to have the same memory leak issue so I can continue to just use BlueIris to stream.
What I can't seem to do is get a Camera Group to stream. Despite all audio channels being enabled on all the cameras in that stream. EDIT: I confirmed no matter what I do, VLC is showing an audio stream with the group. I have Webcast Audio enabled.
Having a problem after installing this latest .34 version. I get this in the logs after "sync my devices"
app:30132022-06-23 04:15:03.901 pm errorError retreiving state for device House Thermostat (Controller) on C4 RF Zigbee: java.lang.NullPointerException: Cannot invoke method multiply() on null object at line 4591 (roundTo)
app:30132022-06-23 04:14:57.682 pm errorjava.lang.NullPointerException: Cannot invoke method multiply() on null object on line 4591 (method handleAction)
Many many hours of projectile swearing until I found out the finicky issue with Google and streams!
I'll have to re-check BlueIris. I had the leak about a year ago, but the developers couldn't readily find it.
How are you doing camera groups? Is that in BlueIris? (I've never did it, so I can try to see if I can figure it out).
