Any plans to allow GVs to set volume in Rule machine.
It would be very handy to set the announcement levels by mode of day.
Thank you
M
Image updated after @Ryan780 pointed out a mistake in my rule
Thank you
M
Instead of the volume have you tried using %variable% instead? The way that this is done, with a speak the message at a volume doesn't work for all TTS devices. Doe sit work when you input just a number?
Also, you realize that your rule will never change the Global Variable, right? You only have actions for True. If the rule is always true, nothing will ever fire. You need a trigger with the trigger event that Mode Changes and then it will set the global variable as you expect.
Since I canβt use that feature Yet ,it was more of a placeholder, to remind me of intentions. I will review what you said. Thank you
You are correct sir. Good catch, hoping to see that feature soon
