This evening a very strange event took place. Without any particular cause that I can discern, every device (I think) in my home turned on at the same time. Looking at the logs, I can't see exactly how/why this happened. Two events took place immediately prior to this happening, but I don't see anything in the logs to connect either thing to this behavior:
A button was pressed and released on a 5-button pico remote which is integrated through telnet. There is a rule triggered by this button press to dim a group of two z-wave RGBW bulbs to 0 (effectively, this is the off button for a pair of lamps in our livingroom.
The time was exactly 7pm. I have rules that are keyed off of certain times of day, and others that are offset from dusk or dawn, but none of these rules are triggered at 7pm, nor was dusk near that time today.
Devices that were turned on included z-wave, zigbee, wifi, and virtual devices and scenes.
My configuration has been pretty static for several months now and I have not recently added any new devices, integrations, etc. I did update from 2.2.5.131 to 2.2.6.140 on April 11th. I have copy/pasted the log entries from 5 minutes before/after the event, but didn't see anything there to explain what happened.
The relevant portion of the logs looks like:
dev:14732021-04-14 19:00:35.149 infoGuest Light: switch was turned on
dev:382021-04-14 19:00:33.346 debugParsed SwitchMultilevelReport(value:99) to [[name:level, value:100, unit:%], [name:switch, value:on]]
dev:11222021-04-14 19:00:29.651 infoNursery Light: switch was turned on
dev:11852021-04-14 19:00:29.491 infoUpstairs Bathroom Light: switch is on
dev:11852021-04-14 19:00:29.488 infoUpstairs Bathroom Light: level is 99
dev:15062021-04-14 19:00:29.082 infoDaniel's Light: switch was turned on
dev:10602021-04-14 19:00:28.013 infoSink Cabinet Parent level is 93%
dev:10602021-04-14 19:00:27.916 infoSink Cabinet Parent level is 93%
dev:10572021-04-14 19:00:27.842 infoCooktop Cabinet Parent level is 67%
dev:10572021-04-14 19:00:27.793 infoCooktop Cabinet Parent level is 67%
dev:10602021-04-14 19:00:27.732 infoSink Cabinet Parent level is 93%
dev:4812021-04-14 19:00:27.254 infoStairway Light is on [digital]
dev:722021-04-14 19:00:26.743 infoBedroom Fan is low [digital]
dev:2272021-04-14 19:00:13.060 infoSBHD was turned off
dev:882021-04-14 19:00:11.654 infoNursery Plug was turned off [digital]
app:12812021-04-14 19:00:11.407 infoAction: Toggle: Nursery Plug
app:12812021-04-14 19:00:11.367 infoBaby Monitor Reboot Triggered
app:12812021-04-14 19:00:11.359 infoBaby Monitor Reboot: Baby Monitor switch off
dev:13452021-04-14 19:00:11.273 infoBaby Monitor was turned off
dev:8652021-04-14 19:00:11.136 infoGarage Door Opener was turned off
dev:3882021-04-14 19:00:10.391 infoDLS was turned off
app:8662021-04-14 19:00:10.315 infoAction: push() on Garage Door
app:8662021-04-14 19:00:10.212 infoGDO Voice Control Triggered
app:8662021-04-14 19:00:10.207 infoGDO Voice Control: Garage Door Opener switch on
dev:8652021-04-14 19:00:10.079 infoGarage Door Opener was turned on
dev:3882021-04-14 19:00:09.842 infoDLS was turned on
dev:9312021-04-14 19:00:09.565 infoDen Light: switch is on
dev:9312021-04-14 19:00:09.558 infoDen Light: level is 99
dev:9642021-04-14 19:00:09.555 infoLivingroom Lamps switch was turned on
dev:7702021-04-14 19:00:09.441 infoPatio Lights: Power report received with value of 147.2 W
dev:11862021-04-14 19:00:09.433 infoUpstairs Bathroom Vent: switch is on
dev:7702021-04-14 19:00:09.342 infoPatio Lights: Power report received with value of 147.2 W
dev:732021-04-14 19:00:09.281 infoMaster Lights switch was turned on
dev:10302021-04-14 19:00:09.179 infoSpicerack Cabinet RGB switch is on
dev:10622021-04-14 19:00:09.070 infoSink Cabinet RGB switch is on
dev:10592021-04-14 19:00:09.011 infoCooktop Cabinet RGB switch is on
dev:13142021-04-14 19:00:08.924 infoGuest Lamp was turned on
dev:382021-04-14 19:00:08.392 debugsetLevel >> value: 100, durationSeconds: null
dev:742021-04-14 19:00:08.296 infoLivingroom Light was set to 14% [digital]
dev:742021-04-14 19:00:08.290 infoLivingroom Light is on [digital]
dev:4502021-04-14 19:00:08.046 infoEntry Light was turned on [digital]
dev:2272021-04-14 19:00:08.041 infoSBHD was turned on
dev:9642021-04-14 19:00:07.976 infoLivingroom Lamps level was set to 0%
dev:9642021-04-14 19:00:07.971 infoLivingroom Lamps switch was off
app:8652021-04-14 19:00:07.918 infoAction: Dim: Livingroom Lamps: 0
app:8652021-04-14 19:00:07.863 infoPico - Livingroom Lamps: Livingroom Pico pushed 5
dev:1312021-04-14 19:00:07.854 infoLivingroom Pico button 5 was released
dev:1322021-04-14 19:00:07.798 inforcvd: DEVICE,2,4,4
app:4842021-04-14 19:00:07.792 infoAction: Off: Fireplace --> delayed: 1:00:00
dev:402021-04-14 19:00:07.780 infoStory Time was turned on
app:4842021-04-14 19:00:07.724 infoFireplace Timeout Triggered
app:4842021-04-14 19:00:07.715 infoFireplace Timeout: Fireplace switch on
dev:4172021-04-14 19:00:07.665 infoSending Message: [Fireplace was set to on at 19:00 on 14-Apr-2021.] Priority: [null] to [All Devices]
dev:1312021-04-14 19:00:07.565 infoLivingroom Pico button 5 was pushed
dev:1322021-04-14 19:00:07.507 inforcvd: DEVICE,2,4,3
dev:10282021-04-14 19:00:07.342 infoSpicerack Cabinet Parent level is 99%
dev:10282021-04-14 19:00:07.272 infoSpicerack Cabinet Parent level is 99%
dev:10282021-04-14 19:00:07.261 infoSpicerack Cabinet Parent level is 99%
dev:4492021-04-14 19:00:06.859 infoFront Porch Light is on [physical]
app:3212021-04-14 19:00:06.823 infoFront Porch Light was turned on
dev:4492021-04-14 19:00:06.672 infoFront Porch Light was turned on [digital]
app:12812021-04-14 19:00:06.571 infoAction: Toggle: Nursery Plug
app:12812021-04-14 19:00:06.457 infoBaby Monitor Reboot Triggered
dev:8342021-04-14 19:00:06.450 infoDaniel's Standlamp was turned on
app:12812021-04-14 19:00:06.446 infoBaby Monitor Reboot: Baby Monitor switch on
dev:10632021-04-14 19:00:06.396 infoKitchen Cabinets switch is on
dev:13452021-04-14 19:00:06.250 infoBaby Monitor was turned on
dev:742021-04-14 19:00:06.211 infoLivingroom Light was turned on [digital]
dev:15082021-04-14 19:00:05.964 infoOffice Lamp was turned on [digital]
dev:8362021-04-14 19:00:05.773 infoNursery Lamp was turned on
dev:762021-04-14 19:00:05.699 infoFrontyard Lights is on [physical]
dev:762021-04-14 19:00:05.605 infoFrontyard Lights is on [digital]
dev:14732021-04-14 19:00:05.513 infoGuest Light: RELAY: switch was turned on
dev:10642021-04-14 19:00:05.213 infoColor Cabinets switch was turned on
dev:8672021-04-14 19:00:04.947 infoDPR was turned on
dev:7702021-04-14 19:00:04.804 infoPatio Lights: Basic report received with value of on
dev:7702021-04-14 19:00:04.768 infoPatio Lights: Basic report received with value of on
dev:9642021-04-14 19:00:04.427 infoLivingroom Lamps level was set to 100%
dev:9642021-04-14 19:00:04.402 infoLivingroom Lamps switch was turned on
dev:822021-04-14 19:00:04.369 infoBackyard Lights is on [digital]
dev:7702021-04-14 19:00:04.282 infoPatio Lights: Basic report received with value of on
dev:9642021-04-14 19:00:04.253 infoLivingroom Lamps colorName is Incandescent
dev:9642021-04-14 19:00:04.231 infoLivingroom Lamps colorTemperature was set to 2700
dev:9642021-04-14 19:00:04.228 infoLivingroom Lamps switch was turned on
dev:822021-04-14 19:00:04.206 infoBackyard Lights is on [digital]
dev:2572021-04-14 19:00:03.947 infoGranola Bars was turned on
dev:7702021-04-14 19:00:03.794 infoPatio Lights: on()
dev:9642021-04-14 19:00:01.901 infoLivingroom Lamps level was set to 0%
dev:9642021-04-14 19:00:01.898 infoLivingroom Lamps switch was off
app:8652021-04-14 19:00:01.794 infoAction: Dim: Livingroom Lamps: 0
dev:1312021-04-14 19:00:01.696 infoLivingroom Pico button 5 was released
dev:1322021-04-14 19:00:01.678 inforcvd: DEVICE,2,4,4
app:8652021-04-14 19:00:01.669 infoPico - Livingroom Lamps: Livingroom Pico pushed 5
dev:1312021-04-14 19:00:01.447 infoLivingroom Pico button 5 was pushed
dev:1322021-04-14 19:00:01.408 inforcvd: DEVICE,2,4,3
dev:7702021-04-14 18:59:25.730 infoPatio Lights: parameter '8' with a byte size of '4' is set to '33491540'
dev:7702021-04-14 18:59:25.038 infoPatio Lights: startNotification(33491540)
dev:7702021-04-14 18:59:25.037 infoPatio Lights: setIndicator(33491540)
I wanted to see if anybody can suggest any deeper data gathering or troubleshooting steps I can take before information is lost or overwritten?
