Alexa skill not displaying devices to authorize
Hello. I have a C-7 running firmware 2.2.5.131 and am trying to enable Alexa integration with no success. When following the instructions, my issue appears on step 8 as I do not see a list of devices. I only see Select Devices:
However, when I look at 'All Devices' in my Alexa app, I see all of my devices. The devices are a mix of Wemo and Wyze plugs, Wyze Cams, and Ecobee thermostats and sensors. I also ensured that my phone is connected to the same WiFi AP as my devices (and HE).
I'm presuming I missed a configuration or authorization somewhere, although I have completed steps 1 -7 in the above linked documentation. Suggestions?
Thank you!
Did you add any Hubitat devices to the App in step #3?
I did not as there were no devices to add:
I think I missed a fundamental point. I need to manually add devices first, and then select what I want Alexa to have access to. My incorrect understanding was that adding the Alexa Skill would bring across all of my existing Alexa-connected devices. <-- did I correct myself correctly?
Correct. This integration gives alexa access to your hubitat devices. It does not give hubitat access to your alexa-connected devices from other services. (if this is what you are looking for, you can find some approaches on the forums using virtual devices and routines in the alexa app that can provide some limited access to use on the Hubitat side.)
Thank you for your guidance, @tony.fleisher!
