Thanksā¦IPv6 already set like that⦠donāt see what changing the ip range from 10⦠to 192⦠will do⦠I have no issues with any other devices on my network ⦠only that Alexa cannot find Hubitat⦠I have a support ticket in with Amazon right now, so weāll see what they say
Just something to try. Wonāt hurt anything. I have experienced devices not routing properly otherwise.
Youāre not likely to get much help from Amazon in this. You have a pre-release product that is emulating a Philips Hue bridge for device discovery. Not supported is a possible response.
Todd,
Do you have an existing Hue Bridge device? If so, does Alexa detect it? Just trying to help narrow it down to the network versus Alexa/Hubitat. Do you have a ST hub? Is the Hubitat hub detected within SmartThings as a Hue Bridge?
Is the Hubitat hub hard-wired directly to the Airport Extreme via Cat5? I have seen problems where people use an Ethernet-to-WiFi bridge device to make a hard-wired device into a WiFi device. Some of these bridges do not pass through all of the traffic necessary for the discovery process to work correctly.
If you have another WiFi router that you can use for testing, it might be interesting to see if there is any change in behavior.
Thanks for the suggestions -
Yes, I have a Hue Bridge and Alexa sees it fine.
My ST hub sees the Hubitat as a Hue Bridge
Hubitat hard wired into Airportā¦
I donāt have another Wifi router but weāve tried some things like removing ST from network, unplugging all but one Echo, support here has been great⦠itās just not working
Iād be inclined to pop down to Best Buy, pick up a different router and try it. If it works maybe thatās your new router if not, return it.
The AirPort Extreme isnāt in Bridge mode is it? No double NAT situation?
I know I may have mentioned this before, but have you tried to discover SCENES in the Alexa app. Itās the only way my new devices get detected and it works every time for me.
Nope, not in bridge modeā¦
yeah, thanks, iāve been doing both devices and scenes since your postā¦
This is exactly what I have and I am having the same problem. I also have the same results as you.
So maybe try bridge mode if you havenāt already. If you arenāt in bridge mode and your ISP router also isnāt in bridge mode, you will get a double NAT. Thatās not necessarily an issue in every instance, but it can cause problems.
It sounds like @todds89 has the same setup as me since we are having the same problem and apparently very similar hardware. That being the case, the airport extreme is the only router we have so there is no possibility of a double NAT setup.
The key thing to remember is that SmartThings seemed to recognize Hubitat as a hue hub just fine and it's on the same network also.
Another thing I'd like to point out is that (at least in my case) alexa finds all of my devices from smartThings and Hue just fine when I search for devices. The only ones not found are from Hubitat. That being the case, if it were a double nat issue, none of this would work.
An ISP router does network address translation. Add your own router behind it without putting either router into bridge mode, youāll have a double NAT. A double NAT isnāt a problem if you donāt have problems that result from it. I operate with a double NAT, and I donāt have network issues. However, in the past I have experienced routing issues that were caused by the double NAT, and the router causing the problem was an Apple TimeCapsule. So at least trying bridge mode is a simple and worthwhile test to try and eliminate possible causes.
Todd, it occurred to me that since the Apple routers only have 3 LAN ports, Iāve seen clients plug into available ports on their ISP router. Thatās not the case here, is it? Hubitat is plugged into the Apple router?
The only thing plugged into the cable modem is the Airport⦠everything (hubitat, echos, ST, Hue Bridge, all other devices) are all on the same network⦠thanks
Try resetting the airport to default?
Seriously though, try another router. Even a cheap 15 dollar tplink or similar.
Maybe Alexa only supports one hue bridge, and it, like Smartthings, sees Hubitat as a hue bridge too. Try removing your hue bridge and then trying again.
I just noticed that both of you having the same problem have a hue bridge.
Good idea, but the Hue bridge was only added to the network a couple days ago - same issues were there before I added it - I even tested it with only the echo (1) and the hubitat (had the ST unplugged, batteries removed⦠thanks
My suspicion is itās a left-over ghost device thatās keeping the new ones from appearing.
Try this:
Remove the Alexa App from Hubitat.
Rename one of your switches to a name youāve never used before (preferably a single word)
Reinstall the Alexa App, and select all switches.
Try to discover devices in Alexa again.
If you only get the one switch that was renamed, itāll help narrow down how to fix this.
