Alexa integration broke with firmware upgrade 2.3.9.162
Hello,
I recently upgraded my C7 hubitat to firmware 2.3.9.162 and then noticed that my alexa was no longer able to control my lights.
I tried rebooting ; disabling and re-enabling the alexa echo skill in my hubitat all got me nowhere, I then noticed that there was a token invalid message showing up in the log (sorry did not capture exact message) ; so once I figured out that the linking was setup from the alexa side of things I went there and disabled the skill ; on re-enabling I could select my hub, but eventually it would say that linking was unsuccessful.
I got things working again after I downgraded the firmware on my hub to 2.3.9.158 (the version I had before upgrading to 2.3.9.162) .. so my question is did the alexa integration (control of hubitat devices from alexa) break / are others experiencing the same issue , or are there people at 2.3.9.162 with working alexa integrations (control of hubitat devices from alexa) and I should try upgrading again..
other info that I think might be useful:
I access my hubitat via http ; have not provided an ssl keypair
I am in Canada
Thank you
If you roll back to your previous version of the platform does it work again?
Yes, once I rolled back to 2.3.9.158 I was able to remake the link and things are working as expected again
@gopher.ny
Working here just fine on .163
The only restrictions I have on my hub is login security.
I am on .162 and have had no Alexa issues. My Alexa integration is also on a C7 hub.
We use Alexa to turn things on and off quite a bit.
no problem here either, wife uses alexa to turn on and off lights and had no problems at all on .162
I went ahead and upgraded my hub again, this time to 2.3.9.163 as that's the option now ; the integration still seems to still be working, so I don't know what was going on when things weren't working for me .. I'm just happy that I'm now at the current version and things look to be OK
