so the plan is this, when my kitchen door is closed, i want a motion sensor to detect if there is any motion in the kitchen, (parents keep leaving dogs in there un knowing they followed them in) it will announce to alexa that a animal is in the kitchen.
i have tried but i am still learning the ropes, i have made a virtual switch and contact sensor but i really got no clue how to bridge the gap.
can somone help if possable, be as namens terms as possable please
I would recommend installing Echo Speaks ( from the Hubitat Package Manager ) or from Here as it puts you in control of your echo from habitat. No workarounds needed.
This is how I would have done it before.
Then create a routine to monitor the contact and make the announcement.
With Echo Speaks at its most basic it would be more like
ok i shall try this, i cant figure out how to get the drivers from GITHUB
Package Manager is the simplest to install.
Click
![Screenshot 2021-06-25 at 09.50.56](https://community.hubitat.com/uploads/default/original/3X/3/7/3737b254cf27c3fcb1e656e5ea6d30869a5e2aae.png)
Then
![Screenshot 2021-06-25 at 09.51.03](https://community.hubitat.com/uploads/default/original/3X/2/1/211821cffce3f69c4e888c29d76cbe60a25e0b6b.png)
Then
![Screenshot 2021-06-25 at 09.51.11](https://community.hubitat.com/uploads/default/original/3X/5/6/56b5b681bd002d626bfa0140c250181fc68df7fa.png)
The paste
https://raw.githubusercontent.com/dcmeglio/hubitat-packagemanager/master/apps/Package_Manager.groovy
into
and then import and save.
Then add a user app.
Then add Echo Speaks from the package manager.
There is a tricky bit when you need to set up the Heroku server but it talks you through that.
what does open() on tmpAlexaConctact come under in Actions?
yeah thtas the bit i got stuck on with the server, i get to a point and then i cant go no further
--EDIT---
±Ok i think i might have got it working now. got to login this time, but i didn't last time.
you need to select custom actions then the device.
Then you are presented with a drop down of actions.
ok, next question.... its coming up in the logs :-
Commands NOT Allowed! Device is currently (OFFLINE) | Type: (volumeControl)
whats next lol?
--EDIT--
Ok it is working i just got to fine tune it a little...
THANK you so much for your help
