I have like 8 Alexa's throughout the house. I'd like to say "Alexa turn on the lights" and have Alexa know which lights to turn on... based which Alexa heard that.
I am using the hubitat Alexa app for the link between the Echo and my lights etc.
A few things go through my head as I sit at work 28 miles from home. Alexa skills might be able to do this without integration other than the devices. Or node red may be able to handle this for you. Maybe better than skills. I know you can check the skills, but maybe someone will weigh in on node red. @aaiyar@stephen_nutt
As far as I'm aware you can only achieve this via Groups. I have an Alexa device in each room, and just say "alexa, lights on (or off)" and my lights will turn on/off, or if dimmers, I can set the level in the same way. On an Alexa by Alexa basis. (or room by room if you prefer).
Exactly what @jwetzel1492 said. One thing to watch for is the naming of the Alexa devices. When you have the rooms set, you can also say “turn off the bedroom” from any room in the house. However, if your Alexa device in the bedroom is also named bedroom Alexa will come back with “bedroom does not support that”. Simple fix is to name the device bedroom Dot or Echo or Show, anything but the exact name of the room.
When I am in the Kitchen I can now say "Lights on/off" and they will do exactly that.
If I'm in another room, I can say "Lights on/off in the Kitchen".
