I am getting this alert and can’t work out why
Any ideas?
Looks like you may have a System Message pending. What happens if you click on the text?
Probably not your issue but I still see the red 1 after dismissing available updates until I refresh the page.
No system message, I suspect a residue of a prior alert.
I had put a trigger on a trv valve, if it changed run xxxx rule.
Damn nearly killed the HE.
The rule was simple if heat is demanded set valve to 99 else set to 0.
So not sure why that would cause a meltdown.
Anyway fixed now.
