I'm new to Hubitat. I'm trying to create a simple Rule that turns off the SimpliSafe alarm when the Mode turns to Day. I installed the Simplisafe driver, and created a virtual Simplisafe device.
In creating the rule:
the trigger is set to be Mode->Day
I then go into Select Actions-> Run Custom Action.
I don't see Alarm under the capability of the action device drop down. Should i be using a different device?
Tagging @homeauto2112, as I am guessing you're using his Driver?
You'd get the best response by posting in the original author's thread below, as that is where the users of this particular integration will get notified of a new post.
Just select "Temperature" from the drop down list. You will then be able to select the SimpliSafe device from your system. Once that is selected, you will be able to access all of its custom commands.
