I have an Aladdin Connect garage door. Using the drivers from @tomw I was able to add the door. It shows up as a device. Now I can manually (from within the device panel itself) open and close the door with by clicking the "open" and "close" command buttons, woohoo!
I have since then purchased a Sonoff SNZB-01 button. I tested and am able to use it and write a "Basic Rule" to make it toggle off/on one of my lights. [this was my test case]
HOWEVER, what I want to do is to have it activate my Aladdin Connect device. My problem is that the Aladdin Connect device does not show up as a choice (like other bulbs and devices) when building a "Basic Rule". What do I need to do to the Aladdin Connect device to make it accessible to the button/Rule. I'm sure it is something simple, but I can't figure it out and have been trying and searching. Thanks!
