Has anyone managed to get Ajax bulbs (in the UK) working properly?
I'm using generic zigbee RGB as the driver but it simply turns on and sets brightness. It doesn't set colour or colour temperature.
Rich
Rich
I've got some Ajaxonline GU10 bulbs working at the moment. Either the Generic zigbee RGBW bulb driver or the Advanced zigbee RGBW bulb driver seems to work ok - just remember to click 'Configure' when you've changed the driver.
Only problem at the moment is that applying a scene to several bulbs doesn't always work first time for all of them. Have to reapply the scene several times to get all the bulbs to change.
I'm about to install the GenericZigbeeRGBWBulbAutoRetry.groovy driver to see if that helps.
Cheers
Rick
Did this go anywhere? I'm having a similar behaviour with my AJAx led strips. Bulbs are fine.
Darren, no mate. I still can't get it to work with Hubitat.
I'm also having issues with Osram Smart+ too!
Sorry for late reply I've eventually set all my ajax bulbs and strips to Advanced Zigbee RGBW Bulb and everything is now running faultless.
