Airplay Integration and Airport Express A1392
Does anyone use the Airport Express Gen 2 for its AirPlay functionality?
My use case:
  1. I have small in-wall speakers near two entry doors that play an audible chime when a door is opened. The previously were keypads for alarm system before implementing Konnected.
  2. The chime is currently played through an Echo Dot located inside my On-Q panel via an Alexa routine.
The goal: Move away from Alexa entirely and transition to HomePods while maintaining this functionality.
The challenge: My On-Q panel doesn't have the depth or room to accommodate a HomePod mini. Installing one just to use its audio output also seems wasteful when I only need the AirPlay functionality, not the speaker itself while also wanting it to be hardwired versus WiFi.
I'd prefer to use an Airport Express Gen 2, for the reasons above, with the existing in-wall speakers rather than build a custom ESP32-based AirPlay audio device and figure out how to trigger it through the available drivers.
Has anyone successfully used an Airport Express Gen 2 with Hubitat to trigger local audio files for events like door chimes or TTS?
I have not personally tested it.. But it should work..
Gen 2 got Airplay 2 with firmware 7.8
Agreed. I just wasn’t sure if there were any known issues with it. I thought I remembered seeing a post about someone having problems with it, but that was quite a while ago.
I mean, it’s $30 on eBay. If it works, great. If not, it goes in the bin with the other 300 items. :joy:
The platform supports Bluetooth speakers on C8P hubs, that could work and be a cheaper alternative for this use case.
Agreed - I'm exploring a few different paths currently.
1- I have a ESP32S3 flashed and currently showing up as an airplay device for testing this weekend.
2- BT speaker testing for possible delays
3- Airport Express Gen 2
4- WiiM Mini
