Milt
November 15, 2023, 9:38pm
1
Hub Model: C8
Versions
Home Assistant 2023.9.2
Supervisor 2023.11.3
Operating System 11.1
Frontend 20230911.0 - latest
After the upgrade, I get two errors under 'Invalid Config'
The following integrations and platforms could not be set up:
In addition the system can not find:
weather-card
button-card
All worked before any of the updates.
The errors you’re referring to are in home assistant?
The links you posted can’t be viewed by others, they appear to point to your server running home assistant.
Are the errors to do with some kind of integration between your Hubitat and home assistant (it is not clear from your post, at least for me)? If so, can you provide details of the integration you are using
system
Closed
November 15, 2024, 1:40am
4
