I've migrated successfully, I think, from a C5 to a C8PRO, using a cloud database backup. Some of my rules have cloud or local endpoints as triggers. How do I read what the new endpoints are?
Did you make sure the C8 Pro is using the same IP address as the old Hub? If so, I am not sure that the endpoint URLs would need to be changed? I use MakerAPI for multiple integrations, and I never had to change the endpoint URLs for that App after two migrations (C7 to C8, C8 to C8 Pro.) I would hope Rule Machine would be the same.
Think I answered my question. Go to trigger, edit endpoint, and the endpoint link shows up. I'm using a different local lan address and the ID changed.
