Aeotec trisensor 8 issues
I connected a new aeotec trisensor 8 and provided custom driver code per Setup TriSensor 8 with Hubitat : Aeotec Help Desk
The issue I'm having is that the dashboards I have for temp readings and battery levels have "??" for this device. And on the actual device page, I don't get any status readings at the top outside of 'motion' (see attached).
any ideas?
It's normal.
Attributes don't get updated until an event occurs from the device.
If, for example, updates are 1 hour, then you shouldn't expect to see a value for an hour. Yours is set for 24hours, which is great, but... :smiley:
The "official" Aeotec driver for TriSensor 8 (ZWA045 on chip 800) does not work for me at all on:
  • Aeotec TriSensor 8 from EU distribution
  • Hubitat C-8 Pro from EU distribution
  • Driver downloaded from Aeotec help desk
  • Device securely paired (S2) through SmartStart
The key issue of the driver is that it lacks a handler for supervision commands arriving from the device. It appears that, at least in my case, TriSensor 8 encapsulates all reports in supervision. Example log:
This can be fairly simply fixed by adding a couple lines of code to the driver pretty anywhere:
// Handle S2 Supervision or device will think communication failed.
def zwaveEvent(hubitat.zwave.commands.supervisionv1.SupervisionGet cmd) {
  def result = []
  logger("trace", "zwaveEvent(SupervisionGet) - cmd: ${cmd.inspect()}")
  hubitat.zwave.Command encapsulatedCommand = cmd.encapsulatedCommand(getCommandClassVersions())
  if (encapsulatedCommand) {
    logger("trace", "zwaveEvent(SupervisionGet) - encapsulatedCommand: ${encapsulatedCommand}")
    result = result + zwaveEvent(encapsulatedCommand)
  } else {
    logger("error", "SupervisionGet - Non-parsed - description: ${description?.inspect()}")
  result = result + response(cmdSequence([zwave.supervisionV1.supervisionReport(sessionID: cmd.sessionID, reserved: 0, moreStatusUpdates: false, status: 0xFF, duration: 0)]))
  return result
There are also other small things in the driver like some Unicode sign before the degree sign, and fingerprint which does not catch both secure and non-secure devices. I have contacted Aeotec support and provided them with my comments, so hopefully they will address this in the source code of the driver published on their support site.
I am sorry if I posted in the wrong place, I just bought Hubitat and I am both new to the ecosystem and groovy.
