Aeotec Smart Switch 7 - color fix and other enhancements
I asked ChatGPT and Claude to create a driver for the Aeotec Smart Switch 7 since I was having issues controlling parameters and color with the built-in driver. The parent driver and child (LED) driver are inline below. Hope this helps. (updated to 3.10 from original post to fix on/off device reporting and add automatic recheck every x minutes for device on/off status, set to be every 60 minutes by default)
import groovy.json.JsonSlurper
import groovy.json.JsonOutput
import groovy.transform.Field
 * Aeotec Smart Switch 7 US (ZWA023) - experimental parent v3.10
 * Hubitat C-8 Pro / Z-Wave JS. Test on one device first.
 * Refresh synchronizes reported configuration values into Preferences; no factory reset or child deletion.
 * v3.10 changes (from v3.9):
 *  - On/off state check is on by default: a blank interval now means 60 minutes (only an
 *    explicit 0 disables it), and it is scheduled when the device is first installed.
 *  - Meter readings (power, energy, voltage, current) are logged only when the value changes,
 *    for both Z-Wave JS and classic reports. Attributes still update on every report.
 * v3.9 changes (from v3.8):
 *  - Hub startup: the full Refresh now runs at a random 1-10 minutes instead of immediately, so
 *    all switches do not refresh at once. The periodic on/off check starts one interval after it.
 *  - Save Preferences: the first periodic on/off check runs at a random 1-10 minutes.
 * v3.8 changes (from v3.7):
 *  - New preference "On/Off State Check Interval" (0 disables; 1-1440 minutes). Periodically
 *    re-reads only the on/off state (Binary Switch Get + Basic Get to endpoint 1) to correct a
 *    missed report. Survives hub reboots; first run is offset by up to 60 s to spread traffic.
 *    A correction is logged at info level.
 *  - Removed the "Test Switch Queries" diagnostic command.
 * v3.7 changes (from v3.6):
 *  - Fixed: a Basic report of 99 (on, Basic uses 0-99) set the switch to off. Any non-zero
 *    numeric value is now on; 0 is off.
 *  - Basic Get responses delivered as {request, response:{currentValue}} are now read too.
 *  - Refresh asks for on/off state twice: Binary Switch Get to endpoint 1 first, then Basic Get to
 *    endpoint 1 after the meter reads, so a single unanswered query no longer leaves state stale.
 *    (Testing: root Binary Switch Get never answers; endpoint 1 Binary Switch Get and Basic Get do.)
 * v3.6 changes (from v3.5):
 *  - Diagnostic command "Test Switch Queries": sends four different on/off state queries
 *    (Binary Switch Get and Basic Get, each to the root and to endpoint 1) 5 seconds apart,
 *    with a log marker before each, to find which one (if any) produces a report.
 *  - Z-Wave JS Basic (CC 0x20) currentValue reports on endpoint 0/1 now update the switch state.
 * v3.5 changes (from v3.4):
 *  - Outlet state is read from endpoint 1 (where the meters are already read) instead of the root.
 *    (Testing showed this alone did not produce a report under Z-Wave JS.)
 * v3.4 changes (from v3.3):
 *  - Configuration parameter readbacks are logged only when diagnostic (debug) logging is on.
 *  - With debug logging on, every parameter returned is logged with a readable label and value
 *    (previously only parameters 1-5 were logged, and always at info level).
 * v3.3 changes (from v3.2):
 *  - LED brightness is capped at 99 (Z-Wave Switch Multilevel maximum); 100 was an invalid value.
 *    "LED On" now restores the last non-zero brightness (default 99).
 *  - Night-light times are logged with correct 0xHHMMSS decoding (18:00 no longer logs as 24:00).
 *  - setConfigurationParameter refuses parameter 255 (Aeotec reset) and parameter 0.
 *  - Pending-write markers expire after 60 seconds, so a lost reply no longer blocks re-saving a value.
 *  - Saving Preferences sends one evenly paced command list instead of many parallel bursts.
 *  - Supervision Get is answered with a Supervision Report (avoids device retransmissions).
 *  - Z-Wave JS reports: only currentValue/currentColor properties update state
 *    (a Binary Switch "duration" or "targetValue" can no longer flip the switch to off).
 *  - LED color is read back after a color change; RGB is sent at full value and the color map's
 *    level is applied once through LED brightness (no double dimming).
 *  - Debug logging turns itself off after 30 minutes; added Reset Energy command.
 *  - Removed undeclared diagnostic/test methods that nothing could call.
metadata {
    definition(name: 'Aeotec Smart Switch 7 US - custom driver', namespace: 'custom.aeotec', author: 'ChatGPT') {
        capability 'Actuator'
        capability 'Switch'
        capability 'Outlet'
        capability 'Refresh'
        capability 'Configuration'
        capability 'Initialize'
        capability 'PowerMeter'
        capability 'EnergyMeter'
        capability 'VoltageMeasurement'
        capability 'CurrentMeter'
        command 'refreshLed'
        command 'resetEnergy'
        command 'setConfigurationParameter', [[name:'Parameter number', type:'NUMBER'], [name:'Length (1, 2 or 4 bytes)', type:'NUMBER'], [name:'Value', type:'NUMBER']]
        command 'getConfigurationParameter', [[name:'Parameter number', type:'NUMBER']]
        attribute 'configurationParameters', 'string'
        attribute 'ledOperatingMode', 'string'
        attribute 'nightlightOnTime', 'string'
        attribute 'nightlightOffTime', 'string'
        attribute 'ledRgbReported', 'string'
        command 'setLedColor', [[name:'Color map', type:'COLOR_MAP']]
        command 'setLedRGB', [[name:'Red 0-255', type:'NUMBER'], [name:'Green 0-255', type:'NUMBER'], [name:'Blue 0-255', type:'NUMBER']]
        command 'setLedLevel', [[name:'Level', type:'NUMBER']]
        command 'setLedOn'
        command 'setLedOff'
        fingerprint mfr:'0371', prod:'0103', model:'0017', deviceJoinName:'Aeotec Smart Switch 7 US'
    preferences {
        input name:'ledOperatingModePreference', type:'enum', title:'LED Operating Mode', options:['unchanged':'Leave unchanged','0':'Disabled','1':'Nightlight','2':'Status'], defaultValue:'unchanged'
        input name:'nightlightOnTime', type:'text', title:'Nightlight ON Time (24-hour HH:mm, 00:00-23:59)', required:false
        input name:'nightlightOffTime', type:'text', title:'Nightlight OFF Time (24-hour HH:mm, 00:00-23:59)', required:false
        input name:'overVoltageProtection', type:'number', title:'Over Voltage Protection (0 disables; 95-255 volts)', required:false, range:'0..255'
        input name:'energyInterval', type:'number', title:'Energy kWh Interval Reporting (0 disables; 1-65535 seconds; 1-30 reports every 30 seconds)', required:false, range:'0..65535'
        input name:'wattInterval', type:'number', title:'Watt Interval Reporting (0 disables; 1-65535 seconds; 1-30 reports every 30 seconds)', required:false, range:'0..65535'
        input name:'voltageInterval', type:'number', title:'Voltage Interval Reporting (0 disables; 1-65535 seconds; 1-30 reports every 30 seconds)', required:false, range:'0..65535'
        input name:'powerRestoreState', type:'number', title:'Default Current State After Power Failure (0 restore last state; 1 ON; 2 OFF)', required:false, range:'0..2'
        input name:'energyThreshold', type:'number', title:'Energy kWh Threshold Reporting (0 disables; 1-10000 kWh)', required:false, range:'0..10000'
        input name:'wattThreshold', type:'number', title:'Watt Threshold Reporting (0 disables; 1-2500 watts)', required:false, range:'0..2500'
        input name:'ampThreshold', type:'number', title:'Amp Threshold Reporting (0 disables; 1-150 in 0.1 amp increments)', required:false, range:'0..150'
        input name:'powerFailReporting', type:'number', title:'Switch State Change Reporting (0 disables; 1 Basic Report; 2 Switch Binary Report)', required:false, range:'0..2'
        input name:'currentInterval', type:'number', title:'Current Amp Interval Reporting (0 disables; 1-65535 seconds; 1-30 reports every 30 seconds)', required:false, range:'0..65535'
        input name:'switchCheckInterval', type:'number', title:'On/Off State Check Interval (0 disables; 1-1440 minutes; blank = 60). Re-reads on/off state to correct a missed report. First check runs 1-10 minutes after saving.', required:false, range:'0..1440', defaultValue:60
        input name:'debugLogging', type:'bool', title:'Enable diagnostic logging (turns off after 30 minutes)', defaultValue:false
        input name:'descriptionLogging', type:'bool', title:'Enable description logging', defaultValue:true
        // Additional documented configuration parameters (shown at bottom of Preferences).
        input name:'overloadProtection', type:'number', title:'Overload Protection (0 disables; 1-1800 watts)', required:false, range:'0..1800'
        input name:'thresholdCheckInterval', type:'number', title:'Threshold Check Interval (0 disables all threshold checks; 1-255 seconds)', required:false, range:'0..255'
        input name:'autoOffTimer', type:'number', title:'Automatic OFF Timer (0 disables; 1-86400 seconds after outlet turns ON)', required:false, range:'0..86400'
        input name:'autoOnTimer', type:'number', title:'Automatic ON Timer (0 disables; 1-86400 seconds after outlet turns OFF)', required:false, range:'0..86400'
@Field static final long PENDING_TIMEOUT_MS = 60000L
@Field static final int LED_MAX_LEVEL = 99
@Field static final int DEFAULT_SWITCH_CHECK_MINUTES = 60
def installed() {
    log.info "${device.displayName}: v3.10 installed; leaving configuration unchanged"
    runIn(3, 'ensureLedChild')
    scheduleSwitchCheck()
def updated() {
    log.info "${device.displayName}: v3.10 preferences saved"
    unschedule('logsOff')
    if(debugLogging) runIn(1800, 'logsOff')
    ensureLedChild()
    List<String> cmds = []
    cmds.addAll(ledOperatingModeCommands())
    cmds.addAll(meteringPreferenceCommands())
    cmds.addAll(nightlightTimeCommands())
    if(cmds) {
        log.info "${device.displayName}: sending ${cmds.size()} configuration commands"
        sendCommands(cmds, 500)
def configure() {
    ensureLedChild()
    List<String> cmds = ledOperatingModeCommands()
    cmds.addAll(refreshCommands())
    sendCommands(cmds, 600)
    runIn(Math.max(22, (int)(cmds.size() * 0.6) + 4), 'refreshLed')
// Runs at hub startup (Initialize capability). The startup Refresh is delayed a random 1-10 minutes
// so all switches do not refresh at once; it already reads on/off, so the periodic check starts
// one interval after it.
def initialize() {
    ensureLedChild()
    int delay = randomStartSeconds()
    runIn(delay, 'refresh')
    if(debugLogging) log.debug "${device.displayName}: startup Refresh in ${delay} s"
    Integer m = switchCheckMinutes()
    scheduleSwitchCheck(m > 0 ? delay + m * 60 : null)
// 60-600 seconds (1-10 minutes).
private int randomStartSeconds() { 60 + new Random().nextInt(541) }
def logsOff() {
    device.updateSetting('debugLogging', [value:'false', type:'bool'])
    log.info "${device.displayName}: diagnostic logging disabled"
def ensureLedChild() {
    if(getChildDevices()) return
    createLedChild()
// Configuration writes. Each *Commands() method returns a command list
// (set + verifying get per parameter) and sends nothing by itself.
private List<String> ledOperatingModeCommands() {
    String requested = settings.ledOperatingModePreference?.toString() ?: 'unchanged'
    if(requested == 'unchanged') return []
    // Only write if the requested mode differs from the last reported device value.
    if(state.ledConfigParameter1?.toString() == requested) return []
    Integer value = requested as Integer
    if(isPending(1, value)) return []
    markPending(1, value)
    return configCommands(1, 1, value)
// Blank fields do not manage the device. Only explicitly populated preferences are written.
// Compare against last reported value to avoid redundant Z-Wave traffic.
private List<String> meteringPreferenceCommands() {
    def definitions = [
        [name:'overVoltageProtection', parameter:11, size:1, min:0, max:255],
        [name:'energyInterval', parameter:24, size:2, min:0, max:65535],
        [name:'wattInterval', parameter:23, size:2, min:0, max:65535],
        [name:'voltageInterval', parameter:25, size:2, min:0, max:65535],
        [name:'powerRestoreState', parameter:8, size:1, min:0, max:2],
        [name:'energyThreshold', parameter:20, size:2, min:0, max:10000],
        [name:'wattThreshold', parameter:21, size:2, min:0, max:2500],
        [name:'ampThreshold', parameter:22, size:1, min:0, max:150],
        [name:'powerFailReporting', parameter:42, size:1, min:0, max:2],
        [name:'currentInterval', parameter:26, size:2, min:0, max:65535],
        [name:'overloadProtection', parameter:10, size:2, min:0, max:1800],
        [name:'thresholdCheckInterval', parameter:19, size:1, min:0, max:255],
        [name:'autoOffTimer', parameter:40, size:4, min:0, max:86400],
        [name:'autoOnTimer', parameter:41, size:4, min:0, max:86400],
    definitions.each { item ->
        def selected = settings[item.name]
        if(selected == null || selected.toString().trim() == '') return
        try {
            long wanted = new BigDecimal(selected.toString().trim()).longValueExact()
            if(wanted < item.min || wanted > item.max || (item.parameter == 11 && wanted != 0 && wanted < 95)) {
                log.warn "${device.displayName}: ${item.name} invalid value ${wanted} (parameter ${item.parameter})"
                return
            def reported = state.reportedConfigurationParameters instanceof Map ? state.reportedConfigurationParameters[item.parameter.toString()] : null
            if(reported != null && reported.toString() == wanted.toString()) return
            // Avoid repeated writes while awaiting a configuration report (expires after 60 s).
            if(isPending(item.parameter, wanted)) return
            markPending(item.parameter, wanted)
            cmds.addAll(configCommands(item.parameter, item.size, wanted))
        } catch(Exception ex) { log.warn "${device.displayName}: invalid preference ${item.name}: ${ex.message}" }
    return cmds
// Aeotec nightlight time: 4-byte 0xRRHHMMSS, clock fields written as hex digits (18:00 = 0x180000).
// Preserve RR on write, and set seconds to zero.
private Integer bcdByte(Integer decimal) { ((int)(decimal / 10) << 4) | (decimal % 10) }
private Integer fromBcdByte(Integer encoded) {
    int tens = (encoded >> 4) & 0xF
    int ones = encoded & 0xF
    if(tens > 9 || ones > 9) return null
    return tens * 10 + ones
private String decodeNightlightTime(Object raw, boolean withSeconds=false) {
    long value = Long.parseLong(raw.toString())
    Integer hour = fromBcdByte((int)((value >> 16) & 0xFF))
    Integer minute = fromBcdByte((int)((value >> 8) & 0xFF))
    Integer second = fromBcdByte((int)(value & 0xFF))
    if(hour == null || minute == null || second == null || hour > 23 || minute > 59 || second > 59) return null
    return withSeconds ? String.format('%02d:%02d:%02d', hour, minute, second) : String.format('%02d:%02d', hour, minute)
private List<String> nightlightTimeCommands() {
    [[name:'nightlightOnTime', parameter:2], [name:'nightlightOffTime', parameter:3]].each { item ->
        String chosen = settings[item.name]?.toString()?.trim()
        if(!chosen) return
        if(!(chosen ==~ /(?:[01][0-9]|2[0-3]):[0-5][0-9]/)) {
            log.warn "${device.displayName}: ${item.name} must be HH:mm (00:00-23:59); received ${chosen}"
            return
        Map reported = state.reportedConfigurationParameters instanceof Map ? state.reportedConfigurationParameters : [:]
        def actual = reported[item.parameter.toString()]
        if(actual == null) {
            log.warn "${device.displayName}: parameter ${item.parameter} not read yet; press Refresh before changing ${item.name}"
            return
        if(decodeNightlightTime(actual) == chosen) return
        int hour = Integer.parseInt(chosen.substring(0,2))
        int minute = Integer.parseInt(chosen.substring(3,5))
        long preservedTop = Long.parseLong(actual.toString()) & 0xFF000000L
        long encoded = preservedTop | ((long)bcdByte(hour) << 16) | ((long)bcdByte(minute) << 8)
        if(isPending(item.parameter, encoded)) return
        markPending(item.parameter, encoded)
        cmds.addAll(configCommands(item.parameter, 4, encoded))
    return cmds
private boolean isPending(Integer parameter, long value) {
    def pending = state["pendingConfig${parameter}"]
    if(!(pending instanceof Map)) return false   // v3.2 stored a bare number; treat as expired
    if(pending.value?.toString() != value.toString()) return false
    return (now() - ((pending.at ?: 0L) as Long)) < PENDING_TIMEOUT_MS
private void markPending(Integer parameter, long value) {
    state["pendingConfig${parameter}"] = [value:value, at:now()]
// Validates and builds ConfigurationSet + ConfigurationGet. Returns [] when rejected.
private List<String> configCommands(Object parameter, Object length, Object value) {
    try {
        int p = Integer.parseInt(parameter.toString())
        int n = Integer.parseInt(length.toString())
        long v = new BigDecimal(value.toString()).longValueExact()
        if(p == 255) throw new IllegalArgumentException('parameter 255 is the Aeotec reset parameter and is blocked by this driver')
        if(p < 1 || p > 254) throw new IllegalArgumentException('parameter must be 1-254')
        if(!(n in [1,2,4])) throw new IllegalArgumentException('length must be 1, 2 or 4')
        long min = -(1L << (8*n-1))
        long max = (1L << (8*n))-1
        if(v < min || v > max) throw new IllegalArgumentException("value must be ${min} through ${max} for ${n} bytes")
        // Unsigned values above the signed range are sent as their two's-complement equivalent,
        // which produces the same bytes on the wire.
        long signedMax = (1L << (8*n-1)) - 1
        int wire = (int)(v > signedMax ? v - (1L << (8*n)) : v)
        log.info "${device.displayName}: writing parameter ${p}, length ${n}, value ${v}"
        return [
            secureCmd(zwave.configurationV2.configurationSet(parameterNumber:p, size:n, scaledConfigurationValue:wire)),
            secureCmd(zwave.configurationV2.configurationGet(parameterNumber:p))
    } catch(Exception e) {
        log.error "${device.displayName}: parameter write rejected: ${e.message}"
        return []
def setConfigurationParameter(Object parameter, Object length, Object value) {
    List<String> cmds = configCommands(parameter, length, value)
    if(cmds) sendCommands(cmds, 450)
def getConfigurationParameter(Object parameter) {
    try {
        if(p < 1 || p > 255) throw new IllegalArgumentException('parameter must be 1-255')
        sendCommands([secureCmd(zwave.configurationV2.configurationGet(parameterNumber:p))])
    } catch(Exception e) { log.error "${device.displayName}: parameter read rejected: ${e.message}" }
private void recordConfigurationParameter(Integer parameter, Object value) {
    if(parameter == null) return
    // Retain a single map rather than one state variable per parameter.
    // Remove legacy per-parameter entries left by earlier driver versions.
    (state.keySet().findAll { it.toString() ==~ /configParam\d+/ }).each { key -> state.remove(key) }
    state.remove("pendingConfig${parameter}")
    Map reported = (state.reportedConfigurationParameters instanceof Map) ? state.reportedConfigurationParameters : [:]
    reported[parameter.toString()] = value
    state.reportedConfigurationParameters = reported
    String json = JsonOutput.toJson(reported)
    if(device.currentValue('configurationParameters') != json) sendEvent(name:'configurationParameters', value:json)
    // Synchronize actual reported values into the Hubitat Preferences UI.
    // Never synthesize a value for a parameter that did not report.
    Map preferenceNames = [
        1:'ledOperatingModePreference', 8:'powerRestoreState',
        11:'overVoltageProtection', 20:'energyThreshold',
        21:'wattThreshold', 22:'ampThreshold', 23:'wattInterval',
        24:'energyInterval', 25:'voltageInterval', 26:'currentInterval',
        10:'overloadProtection', 19:'thresholdCheckInterval',
        40:'autoOffTimer', 41:'autoOnTimer',
        42:'powerFailReporting'
    if(parameter in [2,3]) {
        String timeSetting = parameter == 2 ? 'nightlightOnTime' : 'nightlightOffTime'
        String formatted = decodeNightlightTime(value)
        if(formatted != null) {
            sendEvent(name:timeSetting, value:formatted)
            try {
                if(settings[timeSetting]?.toString() != formatted) device.updateSetting(timeSetting, [value:formatted, type:'text'])
            } catch(Exception ex) { log.warn "${device.displayName}: time preference synchronization failed: ${ex.message}" }
        } else log.warn "${device.displayName}: cannot decode parameter ${parameter} as a clock time: ${value}"
    String preferenceName = preferenceNames[parameter]
    if(preferenceName != null) {
        try {
            String actual = value.toString()
            // A readback following a write supersedes the old preference.
            if(settings[preferenceName]?.toString() != actual) {
                device.updateSetting(preferenceName, [value:actual, type:(parameter == 1 ? 'enum' : 'number')])
            log.warn "${device.displayName}: could not synchronize preference for parameter ${parameter}: ${ex.message}"
    if(parameter == 1) {
        state.ledConfigParameter1 = value
        Integer modeNumber = safeInt(value)
        String mode = (modeNumber != null && modeNumber in [0,1,2]) ? ['Disabled','Nightlight','Status'][modeNumber] : "Unknown (${value})"
        sendEvent(name:'ledOperatingMode', value:mode)
    if(debugLogging) logConfigurationParameter(parameter, value)
// Labels for the parameters this driver reads on Refresh. Parameters without a label are
// still logged, by number and raw value.
@Field static final Map<Integer,String> PARAMETER_LABELS = [
    1:'LED mode (0=disabled, 1=night-light, 2=status)',
    2:'Night-light ON time',
    3:'Night-light OFF time',
    4:'LED blink duration (seconds; 0=no blink)',
    5:'LED blink speed (blinks/second)',
    8:'State after power failure (0=restore last, 1=ON, 2=OFF)',
    10:'Overload protection (watts; 0=disabled)',
    11:'Over-voltage protection (volts; 0=disabled)',
    19:'Threshold check interval (seconds; 0=disabled)',
    20:'Energy threshold reporting (kWh; 0=disabled)',
    21:'Watt threshold reporting (W; 0=disabled)',
    22:'Amp threshold reporting (0.1 A; 0=disabled)',
    23:'Watt interval reporting (seconds; 0=disabled)',
    24:'Energy interval reporting (seconds; 0=disabled)',
    25:'Voltage interval reporting (seconds; 0=disabled)',
    26:'Current interval reporting (seconds; 0=disabled)',
    40:'Automatic OFF timer (seconds; 0=disabled)',
    41:'Automatic ON timer (seconds; 0=disabled)',
    42:'Switch state change reporting (0=disabled, 1=Basic, 2=Switch Binary)'
private void logConfigurationParameter(Integer n, def val) {
    if(n == null) return
    String label = PARAMETER_LABELS[n] ?: 'Parameter'
    String shown = val?.toString()
    if(n in [2,3] && val != null) {
        try {
            String formatted = decodeNightlightTime(val, true)
            shown = formatted ?: "undecodable (${String.format('0x%08X', val as Long)})"
        } catch(Exception ignored) { }
    log.debug "${device.displayName}: ${label} (#${n}) = ${shown}"
// Command plumbing
private String secureCmd(cmd) { zwaveSecureEncap(cmd) }
private String endpointCmd(cmd, Integer ep=2) {
    secureCmd(zwave.multiChannelV3.multiChannelCmdEncap(destinationEndPoint:ep, sourceEndPoint:0, bitAddress:false).encapsulate(cmd))
private void sendCommands(List<String> commands, Integer spacing=250) {
    def valid = commands.findAll { it }
    if(valid) sendHubCommand(new hubitat.device.HubMultiAction(delayBetween(valid, spacing), hubitat.device.Protocol.ZWAVE))
// Outlet
// The set goes to the root (proven to switch the outlet); the verifying get goes to endpoint 1,
// because a root Binary Switch Get produces no report under Z-Wave JS.
def on() { sendCommands([secureCmd(zwave.switchBinaryV1.switchBinarySet(switchValue:255)), endpointCmd(zwave.switchBinaryV1.switchBinaryGet(), 1)], 500) }
def off() { sendCommands([secureCmd(zwave.switchBinaryV1.switchBinarySet(switchValue:0)), endpointCmd(zwave.switchBinaryV1.switchBinaryGet(), 1)], 500) }
private List<String> refreshCommands() {
        endpointCmd(zwave.switchBinaryV1.switchBinaryGet(), 1),
        endpointCmd(zwave.meterV4.meterGet(scale:2), 1),
        endpointCmd(zwave.meterV4.meterGet(scale:0), 1),
        endpointCmd(zwave.meterV4.meterGet(scale:4), 1),
        endpointCmd(zwave.meterV4.meterGet(scale:5), 1),
        // Second, independent on/off query in case the Binary Switch Get above goes unanswered.
        endpointCmd(zwave.basicV1.basicGet(), 1)
    // Read documented parameters. Parameter 255 (reset) is never touched.
    [1,2,3,4,5,6,7,8,9,10,11,19,20,21,22,23,24,25,26,30,31,32,40,41,42].each { n ->
        cmds << secureCmd(zwave.configurationV2.configurationGet(parameterNumber:n))
    return cmds
// Periodic on/off state check (preference "switchCheckInterval", minutes; 0 = disabled).
// Sends only the two on/off queries that answer under Z-Wave JS: Binary Switch Get and
// Basic Get, both to endpoint 1. Uses a self-renewing runIn so any interval 1-1440 works.
private Integer switchCheckMinutes() {
    def raw = settings.switchCheckInterval
    // Hubitat applies a preference's defaultValue only when Preferences are saved, so a blank
    // (never-saved) setting means the default here. Only an explicit 0 disables the check.
    if(raw == null || raw.toString().trim() == '') return DEFAULT_SWITCH_CHECK_MINUTES
    Integer m = null
    try { m = new BigDecimal(raw.toString().trim()).intValue() } catch(Exception ignored) { }
    if(m == null || m < 0 || m > 1440) {
        log.warn "${device.displayName}: On/off check interval must be 0-1440 minutes; received ${raw}. Check disabled."
        return 0
    return m
// First run lands at a random 1-10 minutes (or at firstDelaySeconds when given) so switches
// started together do not all poll at once; later runs follow the interval.
private void scheduleSwitchCheck(Integer firstDelaySeconds = null) {
    unschedule('switchStateCheck')
    if(m > 0) {
        int first = firstDelaySeconds ?: randomStartSeconds()
        runIn(first, 'switchStateCheck')
        if(debugLogging) log.debug "${device.displayName}: on/off check every ${m} min; next in ${first} s"
    } else if(debugLogging) log.debug "${device.displayName}: on/off check disabled"
def switchStateCheck() {
    if(m <= 0) return
    try {
        state.switchCheckAt = now()
        if(debugLogging) log.debug "${device.displayName}: periodic on/off check (switch is ${device.currentValue('switch')})"
        sendCommands([
        ], 3000)
        log.warn "${device.displayName}: periodic on/off check failed: ${e.message}"
    } finally {
        runIn(m * 60, 'switchStateCheck')
def refresh() {
    log.info "${device.displayName}: v3.10 Refresh started"
    try {
        List<String> cmds = refreshCommands()
        // Request LED color after the configuration reads finish (30 x 600 ms = 18 s).
        runIn(22, 'refreshLed')
        log.error "${device.displayName}: Refresh failed: ${e.class.simpleName}: ${e.message}"
def resetEnergy() {
    log.info "${device.displayName}: resetting accumulated energy"
    sendCommands([
        secureCmd(zwave.meterV3.meterReset()),
        endpointCmd(zwave.meterV3.meterReset(), 1),
    ], 600)
// LED (endpoint 2)
def refreshLed() {
    if(debugLogging) log.debug "${device.displayName}: LED endpoint 2 refresh requested"
    // Discard cached RGB so we only publish a complete fresh triplet.
    state.remove('ledRgb2')
    state.remove('ledRgb3')
    state.remove('ledRgb4')
    sendCommands([
        endpointCmd(zwave.switchMultilevelV2.switchMultilevelGet()),
        endpointCmd(zwave.switchColorV3.switchColorGet(colorComponent:2)),
        endpointCmd(zwave.switchColorV3.switchColorGet(colorComponent:3)),
        endpointCmd(zwave.switchColorV3.switchColorGet(colorComponent:4))
    ], 450)
// Existing children are preserved. Hubitat built-in component children may not
// allow changing their driver type. Component callbacks are implemented below.
def createLedChild() {
    def children = getChildDevices()
    if(children) {
        log.warn "${device.displayName}: ${children.size()} existing child(ren); no child created. ${children.collect { it.deviceNetworkId + ' (' + it.typeName + ')' }}"
        return
    String dni = "${device.deviceNetworkId}-LED"
    try {
        addChildDevice('custom.aeotec', 'Aeotec Smart Switch 7 US - custom driver - LED', dni,
            [name:"${device.displayName} LED", label:"${device.displayName} LED", isComponent:true])
        log.info "${device.displayName}: created LED child ${dni}"
    } catch(Exception e) { log.error "Unable to create LED child: ${e.message}" }
private def ledChild() {
    def chosen = children?.find { it.deviceNetworkId?.endsWith('-LED') } ?: children?.find {
        it.displayName?.toLowerCase()?.contains('led') || it.typeName?.toLowerCase()?.contains('led') || it.typeName?.toLowerCase()?.contains('color')
    if(!chosen && children?.size() == 1) chosen = children[0]
    return chosen
private void ledEvent(String name, value, String unit=null) {
    def child = ledChild()
    if(!child) {
        if(debugLogging) log.debug "${device.displayName}: LED ${name}=${value}; no child found"
        return
    try {
        def evt = [name:name, value:value]
        if(unit) evt.unit = unit
        child.sendEvent(evt)
        log.warn "${device.displayName}: LED child event ${name} failed: ${e.message}"
// Hubitat component callbacks used by existing built-in component children.
def componentOn(cd) { log.info "${device.displayName}: LED componentOn ${cd?.deviceNetworkId}"; setLedOn() }
def componentOff(cd) { log.info "${device.displayName}: LED componentOff ${cd?.deviceNetworkId}"; setLedOff() }
def componentSetLevel(cd, level) { log.info "${device.displayName}: LED componentSetLevel ${level}"; setLedLevel(level as Number) }
def componentSetLevel(cd, level, duration) { componentSetLevel(cd, level) }
def componentSetColor(cd, Map color) { log.info "${device.displayName}: LED componentSetColor ${color}"; setLedColor(color) }
def componentSetHue(cd, hue) { setLedColor([hue:hue, saturation:cd?.currentValue('saturation') ?: 100]) }
def componentSetSaturation(cd, sat) { setLedColor([hue:cd?.currentValue('hue') ?: 0, saturation:sat]) }
def componentRefresh(cd) { log.info "${device.displayName}: LED componentRefresh"; refreshLed() }
// Color is sent at full value; brightness is controlled only by Switch Multilevel on
// endpoint 2. When the color map includes a level, it is applied as LED brightness.
def setLedColor(Map color) {
    log.info "${device.displayName}: LED color requested ${color}"
    int hue = Math.max(0, Math.min(100, (color.hue != null ? color.hue : 0) as int))
    int sat = Math.max(0, Math.min(100, (color.saturation != null ? color.saturation : 100) as int))
    def rgb = hubitat.helper.ColorUtils.hsvToRGB([hue, sat, 100])
    // Hubitat hue is 0-100, so primaries do not land exactly (34 = ~122 degrees).
    // Snap fully saturated colors within one hue unit of a primary/secondary to the exact color.
    if(sat == 100) {
        Map<Integer,List<Integer>> exact = [
            0:[255,0,0], 17:[255,255,0], 33:[0,255,0],
            50:[0,255,255], 67:[0,0,255], 83:[255,0,255], 100:[255,0,0]
        Integer near = exact.keySet().find { Math.abs(hue - it) <= 1 }
        if(near != null) rgb = exact[near]
    List<String> cmds = [ledRgbCommand(rgb[0] as Integer, rgb[1] as Integer, rgb[2] as Integer)]
    if(color.level != null) cmds.addAll(ledLevelCommands(color.level as Number))
    sendCommands(cmds, 300)
    runIn(3, 'refreshLed')
def setLedRGB(Number red, Number green, Number blue) {
    int r = Math.max(0, Math.min(255, red.intValue()))
    int g = Math.max(0, Math.min(255, green.intValue()))
    int b = Math.max(0, Math.min(255, blue.intValue()))
    log.info "${device.displayName}: LED RGB requested R=${r} G=${g} B=${b}"
    sendCommands([ledRgbCommand(r, g, b)])
// Same native command path as the tested ZWA023 diagnostic driver:
// Switch Color V3 set with components 2/3/4, Multi Channel V4 to endpoint 2.
private String ledRgbCommand(Integer red, Integer green, Integer blue) {
    def colorCommand = zwave.switchColorV3.switchColorSet(colorComponents: [2:red, 3:green, 4:blue])
    def endpointCommand = zwave.multiChannelV4.multiChannelCmdEncap(destinationEndPoint: 2).encapsulate(colorCommand)
    if(debugLogging) log.debug "${device.displayName}: LED RGB TX ep2 R=${red} G=${green} B=${blue}"
    return zwaveSecureEncap(endpointCommand)
private List<String> ledLevelCommands(Number level) {
    // Switch Multilevel accepts 0-99 (100-254 are reserved), so 100% maps to 99.
    int pct = Math.max(0, Math.min(LED_MAX_LEVEL, level.intValue()))
    if(pct > 0) state.ledLastLevel = pct
    return [endpointCmd(zwave.switchMultilevelV2.switchMultilevelSet(value:pct, dimmingDuration:0)),
            endpointCmd(zwave.switchMultilevelV2.switchMultilevelGet())]
def setLedLevel(Number level) {
    log.info "${device.displayName}: LED brightness requested ${level}"
    sendCommands(ledLevelCommands(level))
def setLedOn() {
    Integer last = safeInt(state.ledLastLevel)
    setLedLevel((last != null && last > 0) ? last : LED_MAX_LEVEL)
def setLedOff() { setLedLevel(0) }
// Parsing
    if(debugLogging) log.debug "${device.displayName} raw: ${description}"
    if(description?.trim()?.startsWith('{')) {
        try {
            Map report = new JsonSlurper().parseText(description) as Map
            handleJsReport(report)
        } catch(Exception e) { log.warn "${device.displayName}: Z-Wave-JS JSON parse error: ${e.message}" }
        return
    try {
        def cmd = zwave.parse(description, [0x20:1, 0x25:1, 0x26:2, 0x32:4, 0x33:3, 0x60:4, 0x70:2, 0x6C:1, 0x86:2, 0x98:1, 0x9F:1])
        if(cmd) zwaveEvent(cmd, 0)
    } catch(Exception e) { log.warn "${device.displayName}: legacy parse error: ${e.message}" }
private void handleJsReport(Map report) {
    Integer cc = safeInt(report.cc)
    Integer ep = safeInt(report.ep) ?: 0
    List values = (report.values instanceof List) ? report.values : []
    if(debugLogging && !values) log.debug "${device.displayName}: JSON report without values: ${report}"
    values.each { entry ->
        if(!(entry instanceof Map)) return
        Integer entryCc = safeInt(entry.commandClass) ?: cc
        Integer endpoint = safeInt(entry.endpoint) ?: ep
        def raw = entry.containsKey('newValue') ? entry.newValue : entry.value
        String prop = entry.propertyName?.toString() ?: entry.property?.toString() ?: ''
        if(debugLogging) log.debug "${device.displayName}: report cc=${entryCc} ep=${endpoint} property=${prop} value=${raw}"
        // Only actual state counts; ignore targetValue, duration and similar properties.
        boolean isCurrent = (prop == '' || prop == 'currentValue')
        // Some Get replies arrive as {request:{...}, response:{currentValue:..., targetValue:...}}.
        if((entryCc == 37 || entryCc == 32) && entry.request instanceof Map && entry.response instanceof Map) {
            raw = (entry.response as Map).currentValue
            isCurrent = true
        String sw = (entryCc == 37 || entryCc == 32) ? switchValueFrom(raw) : null
        if(sw != null && endpoint in [0,1] && isCurrent) {
            Long checkAt = state.switchCheckAt as Long
            if(checkAt && now() - checkAt < 15000 && device.currentValue('switch') != sw)
                log.info "${device.displayName}: periodic check corrected switch state to ${sw}"
            sendEvent(name:'switch', value:sw, descriptionText:"${device.displayName} is ${sw}")
        } else if(entryCc == 112) {
            handleJsConfiguration(entry, raw, endpoint)
        } else if(entryCc == 50) {
            handleJsMeter(entry, raw, endpoint)
        } else if(entryCc == 38 && endpoint == 2 && raw instanceof Number && isCurrent) {
            recordLedLevel((raw as Number).intValue())
        } else if(entryCc == 51 && endpoint == 2 && (prop == '' || prop.startsWith('currentColor'))) {
            handleJsLedColor(entry, raw)
// Binary Switch reports true/false (or 0/255); Basic reports 0-99 or 255. Non-zero = on.
// Returns null for anything unrecognized so it never changes the switch state.
private String switchValueFrom(def raw) {
    if(raw == null) return null
    if(raw instanceof Boolean) return raw ? 'on' : 'off'
    String s = raw.toString().trim()
    if(s.equalsIgnoreCase('true')) return 'on'
    if(s.equalsIgnoreCase('false')) return 'off'
    Integer n = safeInt(s)
    if(n == null || n < 0 || n > 255) return null
    return n > 0 ? 'on' : 'off'
private void handleJsConfiguration(Map entry, def raw, Integer endpoint) {
    // Some Z-Wave-JS ConfigurationGet responses use {request:{args:[1]},response:2}
    // inside the values array instead of a normal property/value event.
    if(entry.request instanceof Map && entry.containsKey('response')) {
        def request = entry.request as Map
        Integer queried = (request.args instanceof List && request.args) ? safeInt(request.args[0]) : null
        if(queried != null) recordConfigurationParameter(queried, entry.response)
        else if(debugLogging) log.debug "${device.displayName}: configuration response with no parameter number: ${entry}"
        return
    def prop = entry.property ?: entry.propertyName
    Integer parameter = safeInt(prop)
    if(parameter == null) parameter = safeInt(entry.parameterNumber)
    if(parameter == null) parameter = safeInt(entry.propertyKey)
    if(parameter != null) recordConfigurationParameter(parameter, raw)
    else if(debugLogging) log.debug "${device.displayName}: configuration report with no parameter number: ${entry}"
private void handleJsLedColor(Map entry, def raw) {
    if(debugLogging) log.debug "${device.displayName}: LED color report ${entry}"
    String key = (entry.propertyKeyName ?: entry.propertyKey ?: entry.colorComponentId ?: '').toString().toLowerCase()
    Integer component = null
    if(key.contains('red') || key == '2') component = 2
    else if(key.contains('green') || key == '3') component = 3
    else if(key.contains('blue') || key == '4') component = 4
    if(component == null) {
        if(debugLogging) log.debug "${device.displayName}: unmatched LED color report ${entry}"
        return
    Integer value = safeInt(raw)
    if(value == null) return
    recordLedColorComponent(component, value)
private Integer safeInt(def n) {
    try { return n == null ? null : Integer.decode(n.toString()) } catch(Exception ignored) { return null }
private void handleJsMeter(Map entry, def raw, Integer endpoint) {
    if(!(raw instanceof Number)) {
        if(debugLogging) log.debug "${device.displayName}: meter value not numeric: ${entry}"
        return
    // Z-Wave-JS Meter propertyKey is a composite identifier, not the scale.
    // The authoritative scale is metadata.ccSpecific.scale (0=kWh, 2=W, 4=V, 5=A).
    Integer scale = safeInt(entry.metadata?.ccSpecific?.scale)
    String attr = null
    String unit = null
    switch(scale) {
        case 0: attr='energy'; unit='kWh'; break
        case 2: attr='power'; unit='W'; break
        case 4: attr='voltage'; unit='V'; break
        case 5: attr='amperage'; unit='A'; break
    // Fall back to exact unit metadata only when the scale is absent.
    if(scale == null) {
        switch(entry.metadata?.unit?.toString()) {
            case 'kWh': attr='energy'; unit='kWh'; break
            case 'W': attr='power'; unit='W'; break
            case 'V': attr='voltage'; unit='V'; break
            case 'A': attr='amperage'; unit='A'; break
    if(attr) {
        meterEvent(attr, raw, unit)
    } else log.warn "${device.displayName}: unrecognized meter scale/property: ${entry}"
// Updates a meter attribute on every report; logs (description logging) only when the value
// differs from the current one, so a refresh or interval report of an unchanged value is quiet.
private void meterEvent(String attr, def value, String unit) {
    boolean changed = true
    try {
        def current = device.currentValue(attr)
        if(current != null && value != null)
            changed = new BigDecimal(current.toString()).compareTo(new BigDecimal(value.toString())) != 0
    sendEvent(name:attr, value:value, unit:unit)
    if(changed && descriptionLogging) log.info "${device.displayName}: ${attr} is ${value} ${unit}"
def zwaveEvent(hubitat.zwave.commands.securityv1.SecurityMessageEncapsulation cmd, Integer ep) {
    def inner = cmd.encapsulatedCommand([0x20:1, 0x25:1, 0x26:2, 0x32:4, 0x33:1, 0x60:3, 0x70:2, 0x6C:1])
    if(inner) zwaveEvent(inner, ep)
def zwaveEvent(hubitat.zwave.commands.multichannelv4.MultiChannelCmdEncap cmd, Integer ignored) {
    def inner = cmd.encapsulatedCommand([0x20:1, 0x25:1, 0x26:2, 0x32:4, 0x33:3, 0x70:2, 0x6C:1])
    if(inner) zwaveEvent(inner, cmd.sourceEndPoint as Integer)
def zwaveEvent(hubitat.zwave.commands.multichannelv3.MultiChannelCmdEncap cmd, Integer ignored) {
    def inner = cmd.encapsulatedCommand([0x20:1, 0x25:1, 0x26:2, 0x32:4, 0x33:1, 0x70:2, 0x6C:1])
// Handle the encapsulated report, then confirm receipt so the device does not retransmit.
def zwaveEvent(hubitat.zwave.commands.supervisionv1.SupervisionGet cmd, Integer ep) {
    def inner = cmd.encapsulatedCommand([0x20:1, 0x25:1, 0x26:2, 0x32:4, 0x33:1, 0x60:3, 0x70:2])
    def report = zwave.supervisionV1.supervisionReport(sessionID:cmd.sessionID, reserved:0, moreStatusUpdates:false, status:0xFF, duration:0)
    sendHubCommand(new hubitat.device.HubAction(ep ? endpointCmd(report, ep) : secureCmd(report), hubitat.device.Protocol.ZWAVE))
def zwaveEvent(hubitat.zwave.commands.switchbinaryv1.SwitchBinaryReport cmd, Integer ep) {
    if(ep == 0 || ep == 1) {
        String val = cmd.value ? 'on' : 'off'
        sendEvent(name:'switch', value:val, descriptionText:"${device.displayName} is ${val}")
def zwaveEvent(hubitat.zwave.commands.basicv1.BasicReport cmd, Integer ep) {
    if(ep == 0 || ep == 1) sendEvent(name:'switch', value:cmd.value ? 'on':'off')
def zwaveEvent(hubitat.zwave.commands.configurationv2.ConfigurationReport cmd, Integer ep) {
    if(cmd.configurationValue instanceof List && cmd.configurationValue) {
        // Documented ZWA023 parameters are unsigned (e.g. 135 V, 600 s), so decode unsigned.
        long v = 0
        cmd.configurationValue.each { b -> v = (v << 8) | ((b as int) & 0xFF) }
        recordConfigurationParameter(cmd.parameterNumber as Integer, v)
def zwaveEvent(hubitat.zwave.commands.meterv4.MeterReport cmd, Integer ep) {
    if(debugLogging) log.debug "Meter report: ${cmd}"
    if(cmd.meterType != 1) return
    switch(cmd.scale as Integer) {
        case 0: meterEvent('energy', cmd.scaledMeterValue, 'kWh'); break
        case 2: meterEvent('power', cmd.scaledMeterValue, 'W'); break
        case 4: meterEvent('voltage', cmd.scaledMeterValue, 'V'); break
        case 5: meterEvent('amperage', cmd.scaledMeterValue, 'A'); break
def zwaveEvent(hubitat.zwave.commands.switchmultilevelv2.SwitchMultilevelReport cmd, Integer ep) {
    if(ep == 2) recordLedLevel(cmd.value as int)
private void recordLedLevel(int level) {
    if(level > 0 && level <= LED_MAX_LEVEL) state.ledLastLevel = level
    ledEvent('level', level, '%')
    ledEvent('switch', level > 0 ? 'on' : 'off')
def zwaveEvent(hubitat.zwave.commands.switchcolorv1.SwitchColorReport cmd, Integer ep) {
    if(ep != 2) return
    recordLedColorComponent(cmd.colorComponent as int, cmd.value as int)
def zwaveEvent(hubitat.zwave.commands.switchcolorv3.SwitchColorReport cmd, Integer ep) {
    if(ep != 2) return
    recordLedColorComponent(cmd.colorComponentId as int, cmd.value as int)
private void recordLedColorComponent(int component, int value) {
    if(!(component in [2,3,4])) return
    state["ledRgb${component}"] = Math.max(0, Math.min(255, value))
    if(![2,3,4].every { state["ledRgb${it}"] != null }) return
    List<Integer> rgb = [state.ledRgb2 as int, state.ledRgb3 as int, state.ledRgb4 as int]
    def hsv = hubitat.helper.ColorUtils.rgbToHSV(rgb)
    ledEvent('hue', hsv[0])
    ledEvent('saturation', hsv[1])
    // Color Switch RGB describes color; level comes from the Switch Multilevel report.
    String hex = String.format('#%02X%02X%02X', rgb[0], rgb[1], rgb[2])
    ledEvent('color', hex)
    sendEvent(name:'ledRgbReported', value:rgb.join(','))
    String colorName = rgb.every { it == 0 } ? 'Black' :
        (rgb[0] > rgb[1]*2 && rgb[0] > rgb[2]*2) ? 'Red' :
        (rgb[1] > rgb[0]*2 && rgb[1] > rgb[2]*2) ? 'Green' :
        (rgb[2] > rgb[0]*2 && rgb[2] > rgb[1]*2) ? 'Blue' :
        (rgb[0] > 200 && rgb[1] > 200 && rgb[2] > 200) ? 'White' : hex
    ledEvent('colorName', colorName)
    if(debugLogging) log.debug "${device.displayName}: LED RGB=${rgb} HSV=${hsv}, color=${hex}"
def zwaveEvent(hubitat.zwave.Command cmd, Integer ep) {
    if(debugLogging) log.debug "Unhandled endpoint ${ep}: ${cmd}"
The child drivers is:
/* Aeotec Smart Switch 7 US LED child - experimental v1.1
 * v1.1: hue/saturation changes no longer resend brightness; removed unused receiveParentEvent.
 * Attributes are published by the parent driver.
metadata {
    definition(name:'Aeotec Smart Switch 7 US - custom driver - LED', namespace:'custom.aeotec', author:'ChatGPT') {
        capability 'Switch'
        capability 'SwitchLevel'
        capability 'ColorControl'
def installed() { log.info "${device.displayName}: LED child installed" }
def updated() { }
def parse(String description) { }
def on() { parent.setLedOn() }
def off() { parent.setLedOff() }
def setLevel(Number level) { parent.setLedLevel(level) }
def setLevel(Number level, Number duration) { parent.setLedLevel(level) }
def setColor(Map color) { parent.setLedColor(color) }
def setHue(Number hue) { parent.setLedColor([hue:hue, saturation:device.currentValue('saturation') ?: 100]) }
def setSaturation(Number saturation) { parent.setLedColor([hue:device.currentValue('hue') ?: 0, saturation:saturation]) }
def refresh() { parent.refreshLed() }
