Thanks to @ chuck.schwer and @ krlaframboise for their help to make this one work
* Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
* in compliance with the License. You may obtain a copy of the License at:
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
* on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
* for the specific language governing permissions and limitations under the License.
metadata {
definition (name: "Aeon Multisensor Gen5", namespace: "Hubitat", author: "keltymd") {
capability "Motion Sensor"
capability "Temperature Measurement"
capability "Relative Humidity Measurement"
capability "Illuminance Measurement"
capability "Configuration"
capability "Sensor"
capability "Battery"
capability "Health Check"
fingerprint deviceId: "0x0701", inClusters: "0x5E,0x86,0x72,0x59,0x85,0x73,0x71,0x84,0x80,0x30,0x31,0x70,0x98,0x7A", outClusters:"0x5A"
fingerprint mfr:"0086", prod:"0102", model:"004A", deviceJoinName: "Aeotec MultiSensor (Gen 5)"
simulator {
status "no motion" : "command: 9881, payload: 00300300"
status "motion" : "command: 9881, payload: 003003FF"
for (int i = 0; i <= 100; i += 20) {
status "temperature ${i}F": new hubitat.zwave.Zwave().securityV1.securityMessageEncapsulation().encapsulate(
new hubitat.zwave.Zwave().sensorMultilevelV2.sensorMultilevelReport(
scaledSensorValue: i, precision: 1, sensorType: 1, scale: 1)
).incomingMessage()
status "humidity ${i}%": new hubitat.zwave.Zwave().securityV1.securityMessageEncapsulation().encapsulate(
new hubitat.zwave.Zwave().sensorMultilevelV2.sensorMultilevelReport(scaledSensorValue: i, sensorType: 5)
).incomingMessage()
for (int i in [0, 20, 89, 100, 200, 500, 1000]) {
status "illuminance ${i} lux": new hubitat.zwave.Zwave().securityV1.securityMessageEncapsulation().encapsulate(
new hubitat.zwave.Zwave().sensorMultilevelV2.sensorMultilevelReport(scaledSensorValue: i, sensorType: 3)
).incomingMessage()
for (int i in [0, 5, 10, 15, 50, 99, 100]) {
status "battery ${i}%": new hubitat.zwave.Zwave().securityV1.securityMessageEncapsulation().encapsulate(
new hubitat.zwave.Zwave().batteryV1.batteryReport(batteryLevel: i)
).incomingMessage()
status "low battery alert": new hubitat.zwave.Zwave().securityV1.securityMessageEncapsulation().encapsulate(
new hubitat.zwave.Zwave().batteryV1.batteryReport(batteryLevel: 255)
).incomingMessage()
status "wake up" : "command: 8407, payload: "
tiles(scale: 2) {
multiAttributeTile(name:"motion", type: "generic", width: 6, height: 4){
tileAttribute ("device.motion", key: "PRIMARY_CONTROL") {
attributeState "active", label:'motion', icon:"st.motion.motion.active", backgroundColor:"#00a0dc"
attributeState "inactive", label:'no motion', icon:"st.motion.motion.inactive", backgroundColor:"#cccccc"
valueTile("temperature", "device.temperature", inactiveLabel: false, width: 2, height: 2) {
state "temperature", label:'${currentValue}°',
backgroundColors:[
[value: 32, color: "#153591"],
[value: 44, color: "#1e9cbb"],
[value: 59, color: "#90d2a7"],
[value: 74, color: "#44b621"],
[value: 84, color: "#f1d801"],
[value: 92, color: "#d04e00"],
[value: 98, color: "#bc2323"]
valueTile("humidity", "device.humidity", inactiveLabel: false, width: 2, height: 2) {
state "humidity", label:'${currentValue}% humidity', unit:""
valueTile("illuminance", "device.illuminance", inactiveLabel: false, width: 2, height: 2) {
state "luminosity", label:'${currentValue} lux', unit:""
valueTile("battery", "device.battery", inactiveLabel: false, decoration: "flat", width: 2, height: 2) {
state "battery", label:'${currentValue}% battery', unit:""
standardTile("configure", "device.configure", inactiveLabel: false, decoration: "flat", width: 2, height: 2) {
state "configure", label:'', action:"configure", icon:"st.secondary.configure"
main(["motion", "temperature", "humidity", "illuminance"])
details(["motion", "temperature", "humidity", "illuminance", "battery", "configure"])
def installed(){
// Device-Watch simply pings if no device events received for 32min(checkInterval)
sendEvent(name: "checkInterval", value: 2 * 60 * 60 + 2 * 60, displayed: false, data: [protocol: "zwave", hubHardwareId: device.hub.hardwareID])
def updated(){
def parse(String description)
def result = null
if (description == "updated") {
result = null
} else {
def cmd = zwave.parse(description, [0x31: 5, 0x30: 1, 0x84: 1])
if (cmd) {
result = zwaveEvent(cmd)
log.debug "Parsed '${description}' to ${result.inspect()}"
return result
def zwaveEvent(hubitat.zwave.commands.wakeupv1.WakeUpNotification cmd)
def result = [createEvent(descriptionText: "${device.displayName} woke up", isStateChange: false)]
if (!isConfigured()) {
// we're still in the process of configuring a newly joined device
log.debug("not sending wakeUpNoMoreInformation yet: late configure")
result += response(configure())
} else {
result += response(zwave.wakeUpV1.wakeUpNoMoreInformation())
result
def zwaveEvent(hubitat.zwave.commands.securityv1.SecurityMessageEncapsulation cmd) {
def encapsulatedCommand = cmd.encapsulatedCommand([0x31: 5, 0x30: 1, 0x84: 1])
// log.debug "encapsulated: ${encapsulatedCommand}"
if (encapsulatedCommand) {
zwaveEvent(encapsulatedCommand)
} else {
log.warn "Unable to extract encapsulated cmd from $cmd"
createEvent(descriptionText: cmd.toString())
def zwaveEvent(hubitat.zwave.commands.batteryv1.BatteryReport cmd) {
def map = [ name: "battery", unit: "%" ]
if (cmd.batteryLevel == 0xFF) {
map.value = 1
map.descriptionText = "${device.displayName} battery is low"
map.isStateChange = true
} else {
map.value = cmd.batteryLevel
state.lastbatt = new Date().time
createEvent(map)
def zwaveEvent(hubitat.zwave.commands.sensormultilevelv5.SensorMultilevelReport cmd)
def map = [:]
switch (cmd.sensorType) {
case 1:
map.name = "temperature"
def cmdScale = cmd.scale == 1 ? "F" : "C"
map.value = convertTemperatureIfNeeded(cmd.scaledSensorValue, cmdScale, cmd.precision)
map.unit = getTemperatureScale()
break;
case 3:
map.name = "illuminance"
map.value = cmd.scaledSensorValue.toInteger()
map.unit = "lux"
break;
case 5:
map.name = "humidity"
map.unit = "%"
break;
default:
map.descriptionText = cmd.toString()
createEvent(map)
def zwaveEvent(hubitat.zwave.commands.sensorbinaryv1.SensorBinaryReport cmd) {
log.trace "SensorBinaryReport: $cmd"
createEvent(name:"motion", value:cmd.sensorValue ? "active" : "inactive")
def zwaveEvent(hubitat.zwave.Command cmd) {
createEvent(descriptionText: cmd.toString(), isStateChange: false)
* PING is used by Device-Watch in attempt to reach the Device
def ping() {
secure(zwave.batteryV1.batteryGet())
def configure() {
// log.debug "configure()"
def request = []
// send temperature, humidity, and illuminance every 1 minute
request << zwave.configurationV1.configurationSet(parameterNumber: 101, size: 4, scaledConfigurationValue: 128|64|32)
request << zwave.configurationV1.configurationSet(parameterNumber: 111, size: 4, scaledConfigurationValue: 60)
// send battery every 20 hours
request << zwave.configurationV1.configurationSet(parameterNumber: 102, size: 4, scaledConfigurationValue: 1)
request << zwave.configurationV1.configurationSet(parameterNumber: 112, size: 4, scaledConfigurationValue: 20*60*60)
// send no-motion report 60 seconds after motion stops
request << zwave.configurationV1.configurationSet(parameterNumber: 3, size: 2, scaledConfigurationValue: 60)
// send binary sensor report instead of basic set for motion
request << zwave.configurationV1.configurationSet(parameterNumber: 5, size: 1, scaledConfigurationValue: 2)
// Turn on the Multisensor Gen5 PIR sensor
request << zwave.configurationV1.configurationSet(parameterNumber: 4, size: 1, scaledConfigurationValue: 1)
// disable notification-style motion events
request << zwave.notificationV3.notificationSet(notificationType: 7, notificationStatus: 1)
request << zwave.batteryV1.batteryGet()
request << zwave.sensorBinaryV2.sensorBinaryGet(sensorType: 0x0C) //motion
request << zwave.sensorMultilevelV5.sensorMultilevelGet(sensorType: 0x01) //temperature
request << zwave.sensorMultilevelV5.sensorMultilevelGet(sensorType: 0x03) //illuminance
request << zwave.sensorMultilevelV5.sensorMultilevelGet(sensorType: 0x05) //humidity
setConfigured()
secureSequence(request) + ["delay 20000", zwave.wakeUpV1.wakeUpNoMoreInformation().format()]
private setConfigured() {
device.updateDataValue("configured", "true")
private isConfigured() {
device.getDataValue(["configured"]).toString() == "true"
private secure(hubitat.zwave.Command cmd) {
zwave.securityV1.securityMessageEncapsulation().encapsulate(cmd).format()
private secureSequence(commands, delay=200) {
delayBetween(commands.collect{ secure(it) }, delay)
