dev:99 2020-06-09 04:36:13.602 pm info Humidity is 40%
dev:99 2020-06-09 04:36:13.599 pm debug raw humidity = 40
dev:99 2020-06-09 04:36:13.595 pm debug In multi level report cmd = SensorMultilevelReport(precision:0, scale:0, sensorType:5, sensorValue:[40], size:1, scaledSensorValue:40)
dev:99 2020-06-09 04:36:11.904 pm info Ultraviolet index is 0
dev:99 2020-06-09 04:36:11.901 pm debug raw uv index = 0
dev:99 2020-06-09 04:36:11.898 pm debug In multi level report cmd = SensorMultilevelReport(precision:0, scale:0, sensorType:27, sensorValue:[0], size:1, scaledSensorValue:0)
dev:99 2020-06-09 04:36:11.860 pm info Illuminance is 0 Lux
dev:99 2020-06-09 04:36:11.856 pm debug raw illuminance = 0
dev:99 2020-06-09 04:36:11.852 pm debug In multi level report cmd = SensorMultilevelReport(precision:0, scale:1, sensorType:3, sensorValue:[0, 0], size:2, scaledSensorValue:0)
dev:99 2020-06-09 04:36:08.616 pm info Temperature is 82.4°F
dev:99 2020-06-09 04:36:08.613 pm debug finalval = 82.4
dev:99 2020-06-09 04:36:08.610 pm debug raw temp = 28.0
dev:99 2020-06-09 04:36:08.606 pm debug In multi level report cmd = SensorMultilevelReport(precision:1, scale:0, sensorType:1, sensorValue:[1, 24], size:2, scaledSensorValue:28.0)
dev:99 2020-06-09 04:36:07.476 pm debug In BatteryReport
dev:99 2020-06-09 04:36:07.219 pm info Motion is inactive by SensorBinaryReport
dev:99 2020-06-09 04:36:05.537 pm info You are using the current version of this driver
dev:99 2020-06-09 04:36:02.365 pm info Temperature is 82.4°F
dev:99 2020-06-09 04:36:02.362 pm debug finalval = 82.4
dev:99 2020-06-09 04:36:02.359 pm debug raw temp = 82.4
dev:99 2020-06-09 04:36:02.356 pm debug In multi level report cmd = SensorMultilevelReport(precision:1, scale:1, sensorType:1, sensorValue:[3, 56], size:2, scaledSensorValue:82.4)
dev:99 2020-06-09 04:35:52.701 pm info Ultraviolet index is 0
dev:99 2020-06-09 04:35:52.698 pm debug raw uv index = 0
dev:99 2020-06-09 04:35:52.695 pm debug In multi level report cmd = SensorMultilevelReport(precision:0, scale:0, sensorType:27, sensorValue:[0], size:1, scaledSensorValue:0)
dev:99 2020-06-09 04:35:52.617 pm info Illuminance is 0 Lux
dev:99 2020-06-09 04:35:52.614 pm debug raw illuminance = 0
dev:99 2020-06-09 04:35:52.611 pm debug In multi level report cmd = SensorMultilevelReport(precision:0, scale:1, sensorType:3, sensorValue:[0, 0], size:2, scaledSensorValue:0)
dev:99 2020-06-09 04:35:52.601 pm debug In BatteryReport
dev:99 2020-06-09 04:35:51.762 pm info Humidity is 40%
dev:99 2020-06-09 04:35:51.759 pm debug raw humidity = 40
dev:99 2020-06-09 04:35:51.756 pm debug In multi level report cmd = SensorMultilevelReport(precision:0, scale:0, sensorType:5, sensorValue:[40], size:1, scaledSensorValue:40)
dev:99 2020-06-09 04:35:51.686 pm info Temperature is 82.3°F
dev:99 2020-06-09 04:35:51.682 pm debug finalval = 82.3
dev:99 2020-06-09 04:35:51.678 pm debug raw temp = 82.3
dev:99 2020-06-09 04:35:51.675 pm debug In multi level report cmd = SensorMultilevelReport(precision:1, scale:1, sensorType:1, sensorValue:[3, 55], size:2, scaledSensorValue:82.3)
dev:99 2020-06-09 04:35:47.333 pm debug productTypeId: 258
dev:99 2020-06-09 04:35:47.330 pm debug model: US
dev:99 2020-06-09 04:35:47.326 pm debug productId: 100
dev:99 2020-06-09 04:35:47.323 pm debug manufacturerName: AEON Labs
dev:99 2020-06-09 04:35:47.023 pm debug manufacturerId: 134
dev:99 2020-06-09 04:35:47.019 pm debug ManufacturerSpecificReport cmd = ManufacturerSpecificReport(manufacturerId:134, productId:100, productTypeId:258)
dev:99 2020-06-09 04:35:45.881 pm debug ---VERSION REPORT V1--- MultiSensor6 is running firmware version: 1.13, Z-Wave version: 4.54
dev:99 2020-06-09 04:35:45.871 pm debug in version report
dev:99 2020-06-09 04:35:44.745 pm debug Sending Z-wave command: SensorMultilevelGet(sensorType:27, scale:0)
dev:99 2020-06-09 04:35:44.742 pm debug Sending Z-wave command: SensorMultilevelGet(sensorType:5, scale:0)
dev:99 2020-06-09 04:35:44.738 pm debug Sending Z-wave command: SensorMultilevelGet(sensorType:3, scale:0)
dev:99 2020-06-09 04:35:44.735 pm debug Sending Z-wave command: SensorMultilevelGet(sensorType:1, scale:0)
dev:99 2020-06-09 04:35:44.720 pm debug Sending Z-wave command: SensorBinaryGet()
dev:99 2020-06-09 04:35:44.710 pm debug Sending Z-wave command: BatteryGet()
dev:99 2020-06-09 04:35:44.702 pm debug Sending Z-wave command: ConfigurationSet(configurationValue:[0], defaultValue:false, parameterNumber:81, reserved11:0, size:1)
dev:99 2020-06-09 04:35:44.698 pm debug Sending Z-wave command: ConfigurationSet(configurationValue:[0, 0], defaultValue:false, parameterNumber:203, reserved11:0, size:2)
dev:99 2020-06-09 04:35:44.694 pm debug Sending Z-wave command: ConfigurationSet(configurationValue:[0], defaultValue:false, parameterNumber:202, reserved11:0, size:1)
dev:99 2020-06-09 04:35:44.690 pm debug Sending Z-wave command: ConfigurationSet(configurationValue:[0, 2], defaultValue:false, parameterNumber:201, reserved11:0, size:2)
dev:99 2020-06-09 04:35:44.686 pm debug Sending Z-wave command: ConfigurationSet(configurationValue:[2], defaultValue:false, parameterNumber:5, reserved11:0, size:1)
dev:99 2020-06-09 04:35:44.682 pm debug Sending Z-wave command: ConfigurationSet(configurationValue:[0, 100], defaultValue:false, parameterNumber:43, reserved11:0, size:2)
dev:99 2020-06-09 04:35:44.679 pm debug Sending Z-wave command: ConfigurationSet(configurationValue:[10], defaultValue:false, parameterNumber:42, reserved11:0, size:1)
dev:99 2020-06-09 04:35:44.672 pm debug Sending Z-wave command: ConfigurationSet(configurationValue:[0, 2, 2, 0], defaultValue:false, parameterNumber:41, reserved11:0, size:4)
dev:99 2020-06-09 04:35:44.669 pm debug Sending Z-wave command: ConfigurationSet(configurationValue:[2], defaultValue:false, parameterNumber:64, reserved11:0, size:1)
dev:99 2020-06-09 04:35:44.665 pm debug Sending Z-wave command: ConfigurationSet(configurationValue:[1], defaultValue:false, parameterNumber:40, reserved11:0, size:1)
dev:99 2020-06-09 04:35:44.661 pm debug Sending Z-wave command: ConfigurationSet(configurationValue:[0, 0, 28, 32], defaultValue:false, parameterNumber:112, reserved11:0, size:4)
dev:99 2020-06-09 04:35:44.657 pm debug Sending Z-wave command: ConfigurationSet(configurationValue:[0, 0, 1, 44], defaultValue:false, parameterNumber:111, reserved11:0, size:4)
dev:99 2020-06-09 04:35:44.654 pm debug Sending Z-wave command: ConfigurationSet(configurationValue:[5], defaultValue:false, parameterNumber:4, reserved11:0, size:1)
dev:99 2020-06-09 04:35:44.651 pm debug Sending Z-wave command: ConfigurationSet(configurationValue:[0, 60], defaultValue:false, parameterNumber:3, reserved11:0, size:2)
dev:99 2020-06-09 04:35:44.647 pm debug Sending Z-wave command: ConfigurationSet(configurationValue:[0, 0, 0, 1], defaultValue:false, parameterNumber:102, reserved11:0, size:4)
dev:99 2020-06-09 04:35:44.643 pm debug Sending Z-wave command: ConfigurationSet(configurationValue:[0, 0, 0, 241], defaultValue:false, parameterNumber:101, reserved11:0, size:4)
dev:99 2020-06-09 04:35:44.618 pm debug Sending Z-wave command: AssociationSet(groupingIdentifier:2, nodeId:1)
dev:99 2020-06-09 04:35:44.615 pm debug Sending Z-wave command: AssociationSet(groupingIdentifier:1, nodeId:1)
dev:99 2020-06-09 04:35:44.601 pm debug Sending Z-wave command: ManufacturerSpecificGet()
dev:99 2020-06-09 04:35:44.594 pm debug Sending Z-wave command: VersionGet()
dev:99 2020-06-09 04:35:44.586 pm debug Sending Z-wave command: WakeUpIntervalSet(nodeid:1, seconds:300)
dev:99 2020-06-09 04:35:44.450 pm debug Location temperature scale: F
dev:99 2020-06-09 04:35:44.446 pm debug Current firmware: 0.00
dev:99 2020-06-09 04:35:44.427 pm debug wake time reset to 300
dev:99 2020-06-09 04:35:44.411 pm debug LED Option = 0
dev:99 2020-06-09 04:35:44.408 pm debug Min Lux change for reporting = 100
dev:99 2020-06-09 04:35:44.405 pm debug Min Humidity change for reporting = 10
dev:99 2020-06-09 04:35:44.401 pm debug Min Temp change for reporting = 2
dev:99 2020-06-09 04:35:44.398 pm debug Humidity adjust = 0
dev:99 2020-06-09 04:35:44.395 pm debug Temperature adjust = 0 (0°)
dev:99 2020-06-09 04:35:44.391 pm debug Motion Sensitivity = 5
dev:99 2020-06-09 04:35:44.388 pm debug Motion Delay Time = 1 minute
dev:99 2020-06-09 04:35:44.384 pm debug Report Interval = 5 minutes
dev:99 2020-06-09 04:35:44.369 pm info MultiSensor6 is configuring its settings
dev:99 2020-06-09 04:35:44.366 pm debug ccc: 1
dev:99 2020-06-09 04:35:44.357 pm debug Sending Z-wave command: ConfigurationGet(parameterNumber:101)
dev:99 2020-06-09 04:35:44.329 pm warn power source is not identified, check that sensor is powered by USB, if so > configure()
dev:99 2020-06-09 04:35:44.130 pm debug MultiSensor6 is now on null power
dev:99 2020-06-09 04:35:44.114 pm debug In Updated with settings: [motionSens:5, luxThold:100, refTemp:null, logEnable:true, txtEnable:true, luxOffset:0, reportInterval:5 minutes, luxChangeAmount:100, ledOptions:0, debug Output:true, motionSensitivity:5, humidChangeAmount:10, descTextEnable:true, humidOffset:0, selectiveReporting:true, tempChangeAmount:2, motionDelayTime:1 minute, tempOffset:0, settingEnable:true]
dev:99 2020-06-09 04:34:54.949 pm debug NotificationReport: NotificationReport(v1AlarmType:0, v1AlarmLevel:0, reserved:0, notificationStatus:255, notificationType:7, event:0, sequence:false, eventParametersLength:0, eventParameter:[])
dev:99 2020-06-09 04:34:54.944 pm debug parse: zw device: 2B, command: 7105, payload: 00 00 00 FF 07 00 00 , isMulticast: false
dev:99 2020-06-09 04:34:54.652 pm info MultiSensor6 motion is inactive
dev:99 2020-06-09 04:34:54.649 pm debug BasicSet: BasicSet(value:0)
dev:99 2020-06-09 04:34:54.646 pm debug parse: zw device: 2B, command: 2001, payload: 00 , isMulticast: false
dev:99 2020-06-09 04:34:31.338 pm info MultiSensor6 UV index is 0
dev:99 2020-06-09 04:34:31.332 pm debug SensorMultilevelReport: SensorMultilevelReport(precision:0, scale:0, sensorType:27, sensorValue:[0], size:1, scaledSensorValue:0)
dev:99 2020-06-09 04:34:31.324 pm debug parse: zw device: 2B, command: 3105, payload: 1B 01 00 , isMulticast: false
dev:99 2020-06-09 04:34:31.269 pm info MultiSensor6 illuminance is 0 Lux
dev:99 2020-06-09 04:34:31.264 pm debug SensorMultilevelReport: SensorMultilevelReport(precision:0, scale:1, sensorType:3, sensorValue:[0, 0], size:2, scaledSensorValue:0)
dev:99 2020-06-09 04:34:31.249 pm debug parse: zw device: 2B, command: 3105, payload: 03 0A 00 00 , isMulticast: false
dev:99 2020-06-09 04:34:31.178 pm info MultiSensor6 battery level is 100%
dev:99 2020-06-09 04:34:31.173 pm debug BatteryReport: BatteryReport(batteryLevel:100)
dev:99 2020-06-09 04:34:31.166 pm debug parse: zw device: 2B, command: 8003, payload: 64 , isMulticast: false
dev:99 2020-06-09 04:34:30.396 pm info MultiSensor6 humidity is 42%
dev:99 2020-06-09 04:34:30.391 pm debug SensorMultilevelReport: SensorMultilevelReport(precision:0, scale:0, sensorType:5, sensorValue:[42], size:1, scaledSensorValue:42)
dev:99 2020-06-09 04:34:30.383 pm debug parse: zw device: 2B, command: 3105, payload: 05 01 2A , isMulticast: false
dev:99 2020-06-09 04:34:30.275 pm info MultiSensor6 temperature is 81.1°F
dev:99 2020-06-09 04:34:30.265 pm debug SensorMultilevelReport: SensorMultilevelReport(precision:1, scale:1, sensorType:1, sensorValue:[3, 43], size:2, scaledSensorValue:81.1)
dev:99 2020-06-09 04:34:30.247 pm debug parse: zw device: 2B, command: 3105, payload: 01 2A 03 2B , isMulticast: false
--- Live Log Started, waiting for events ---
