Since at least release 2.3.9.177 on my C7, my Dual Nano switch is not reporting the current state for either if the component devices (Switch:1 or Switch:2). I can command both components on or off manually via the devices menu or HomeKit but this is interfering with my simple automation rules. I'm not sure where to start.
Any suggestions? Thanks
There haven't been any changes to this driver since platform 2.2.6 other than adding the type (physical/digital) attribute to events generated by the child devices in 2.3.9.158, so that is likely unrelated. But in the odd case it's not: do you see information coming in that is somehow not being parsed by the driver (it would probably say something about BasicReport or SwitchBinaryReport) if you enable debug logging?
Thanks for the direction. I enabled logging for both component switches and monitored for about 24hrs but didn’t see anything like what you described. So, I turned it off and back on again by cycling the circuit breaker for 30 seconds. It appears to be behaving better now but I will keep an eye on it. Thank you.
