Aeotec Dual Nano Dimmer - ZW111
Using a C7 with 2.2.4.158.
I have paired this device with Hubitat, and it comes up using the driver for "AEOTEC Dual Nano Switch". (See below).
This is the dimmer, not the switch. Am I using the wrong driver for this dimmer?
(There doesn't appear to be a driver for the Aeotec Nano Dual Dimmer).
I have the exact same device and that's what it shows on mine as well. Did not even think about it! Device is 10 ft away from hub in same room. One switch is power only and the delay on it is terrible - 5-7 seconds to register an event - the other is a single pole connection and works fine. I am going to swap the Aeotec for some Zooz dimmers.
Hmmm....
It appears that the ZW132 is the Aeotec Dual Nano Switch
and the ZW111 is the Aeotec Dual Nano Dimmer.
There may be some issues in Hubitat addressing a dimmer as a switch (or vice versa).
I recently had issues with this switch - it suddenly went on (totally unexplained), and didn't turn on when expected to. In examining why, the only issue that I can find is that I'm using the driver for the switch and not the dimmer. If that's not the cause, then ....
Does anyone know the specific zwave clusters that identify the switch as a dimmer?
Might be yet another driver thing to report to @bcopeland...
I have this device (ZW111) on my C5 and its a Aeotec Dimmer. Never heard of a dual dimmer?
Yeah there is no such thing as a dual nano dimmer. Only a nano dimmer or a dual nano switch ( energy or none).
@jtmpush18 You want to select this. From memory mine selected the correct driver, so what firmware version are you on?
Only in Canada, eh?
I think that I must be mistaken.
(Haha, it does happen, but only sometimes!)
You are quite right, there is no Nano Dual Dimmer, only a Nano Dual Switch.
Very sad.. I thought I had some extra functionality... anyway not a big fan of the dual switch so will be replacing it.
