Is it possible to connect my Aetec cam360 to my hub?
Did you check the list of compatible devices?
https://docs.hubitat.com/index.php?title=List_of_Compatible_Devices
There is also a link in there for community supported devices.
Hey guys and ladies. I know that the Cam360 doesnโt work outside of ST. But my question is whether any of you have looked at ways to replace the drivers and make it work on HE?
When I was on ST, I loved the way I could use the Cam360 to trigger alerts directly in ST. But I donโt feel like using ST just to use my Cams, and while ST was great for a newb, I am over it and its privacy issues.
As always, thanks so much
My suggestion would be to setup node red to bring the camera events into HE from Smartthings. Basically it just means usikg ST as a cloud aggregator.
If you are interested look up using Samsung Automation Studio with Arlo. The same idea would apply.
