I just install an Aeon Smartstrip It discover the device and all the button seems to be there. When I push the off and on buttons it works, but when I push button 1 or button 2 etc off and on it doesn't? Is there something else that I need to do? I have try to use the reset button but doesn't do anything?
Just wanted to check on this am I the only one with this problem or the only one with an Aeon Smartstrip?
I have a few, but havenāt had time to try and pair one yet. I need to get power monitoring to my InfluxDB working before I can move things over unfortunately.
I have one of these on my SmartThings setup. It required a companion app (Iām using āVirtual/Physical Switch Syncā on ST) to allow individual operation of the 4 controllable outlets and and report their status in the St app. I assume there is no companion app available so the only on/off control is the single master switch that affects all 4 outlets.
I donāt have the smartstrip but I do have the Aeon Smart Plug 6 and it paired and works fine with the included driver.
Yeah this is a unique device, it has 7 outlets, 4 switches, 2 not, 1 thatās ALL.
It took some effort for the ST version to get where it is.
Also required parent/child thatās not yet supported here.
I assume you can use RM to control all the outlets though as theyād show up under custom commandsā¦
Thanks everyone for the response. Didnāt realize that the parent / child wasnāt supported. I guess that I will have to wait.
Just wanted to check and see if this was fix or being work on?
@bobbyD I just want to thank you and the Hubitat team for getting this to work. Thank you all for doing this.
Tried this out today for the first time; nice to see that WebCore can access the individual outlets as well.
Have you noticed that an error is logged anytime that a switch is manipulated? Iām seeing these messages when I turn any outlet on or off (either by the device UI or by an app):
2018-03-27 17:20:12.192: error toIndex = 8 on line null
@Tony I have not seen that? Where are you seeing that at?
It appears on the live logging page. Iāve emailed support (Iām also not seeing power reported properly) and they are looking into it.
I'm also quite interested in this device being fully supported. I have 4 strips using the erocm smartapp in ST that creates 4 individually controllable devices per strip.
Has there been any mention of plans to support this device?
@beedix77 I'm using that in Hubitat and it works good and I'm able to control each one separate that controllable. If you need I will point you to the device handler that I'm using.
@leeonestop I would greatly appreciate a link to something that is working!
@beedix77 Sorry just got home but you can install and use the Aeon Smartstrip that is install when you join the smartstrip to Hubitat.
