Hello there, I am moving over from SmartThings and so far so good. I made a test dashboard and added my aeon smart switch 6 to it, but in the dashboard just show the energy used. How to I get to switch it on and off? Thanks in advance. I am sure there is going to be more questions.
The Smart Switch 6 is many devices in one...
Power
Voltage
Energy
Current
and oh yes, a switch
On Dashboard you can display Attributes with the Attributes Template/Tile. So just add a Tile, for your device, using Switch Template. You can place them over each other if it looks good.
That's an RGB bulb, at the back is the regular tile. Click on it, opens to:
Kind of a lot of clicking to just turn on a bulb. So I put a smaller switch tile on top. Click the bottom "half" the bulb goes on or off. Click the top "half" and the usual popup displays.
Thanks I was messing around with the tiles and I just found out how to do it. I
