@ogiewon Getting this error. Seems you are possibly familiar from your early experience with this, although it seems to be different. Are you able to offer a suggestion of what I've done that might cause this?
[dev:4509](http://192.168.0.113/logs/past#dev4509)2019-11-12 07:25:04.611 am [error](http://192.168.0.113/device/edit/4509)groovy.lang.MissingPropertyException: No such property: scale for class: hubitat.zwave.commands.meterv4.MeterSupportedGet on line 59 (parse)
Here's the most recent code with my changes which added buttons 3 & 4, but that was quite a while ago, and it's been running with those changes and no error until now. Only other thing I have changed recently is the word "dryer" to "microwave", and the name of the driver for my own use. Prior to that I don't recall seeing any errors.
Custom Laundry monitor device for Aeon HEM V1
originally written by Mike Maxwell for SmartThings
modified by Dan Ogorchock to work with Hubitat
modified by Douglas Krug - Added button 3 and 4 push to indicate washer is running. For washers, this allows cancellation
of rule actions to prevent false notifications with washers having a very tight running wattage range,
and therefore fluctuating between ON and OFF status many times during a wash cycle. This also allows button push 3 and 4
to trigger virtual switches so the status of the each machine can be used with google voice assistant for verbal response.
Changed device from dryer to microwave, and driver name
metadata {
definition (name: "Aeon HEM V1 Appliance ON/OFF Monitor", namespace: "logname", author: "Douglas Krug")
capability "Configuration"
capability "Switch"
capability "Button"
//capability "Energy Meter"
capability "Actuator"
capability "Pushable Button"
capability "Holdable Button"
capability "Sensor"
attribute "washerWatts", "string"
attribute "microwaveWatts", "string"
attribute "washerState", "string"
attribute "microwaveState", "string"
fingerprint deviceId: "0x2101", inClusters: " 0x70,0x31,0x72,0x86,0x32,0x80,0x85,0x60"
preferences {
input name: "washerRW", type: "number", title: "Washer running watts:", description: "", required: true
input name: "microwaveRW", type: "number", title: "Microwave running watts:", description: "", required: true
//log.trace "Parse received ${description}"
def result = null
def cmd = zwave.parse(description, [0x31: 1, 0x32: 1, 0x60: 3])
if (cmd) {
result = createEvent(zwaveEvent(cmd))
if (result) {
//log.debug "Parse returned ${result?.descriptionText}"
return result
} else {
def zwaveEvent(hubitat.zwave.commands.multichannelv3.MultiChannelCmdEncap cmd) {
//log.info "mc3v cmd: ${cmd}"
if (cmd.commandClass == 50) {
def encapsulatedCommand = cmd.encapsulatedCommand([0x30: 1, 0x31: 1])
if (encapsulatedCommand) {
def scale = encapsulatedCommand.scale
def value = encapsulatedCommand.scaledMeterValue
def source = cmd.sourceEndPoint
def str = ""
def name = ""
if (scale == 2 ){ //watts
str = "watts"
if (source == 1){
name = "washerWatts"
if (value.toInteger() >= settings.washerRW.toInteger()){
//washer is on
//if (state.washerIsRunning == false){
if (device.currentValue("washerState") == "off"){
//washer is running
sendEvent(name: "pushed", value: "3", descriptionText: "Washer is running.", isStateChange: true)
sendEvent(name: "washerState", value: "on", displayed: true)
state.washerIsRunning = true
} else {
//washer is off
//if (state.washerIsRunning == true){
if (device.currentValue("washerState") == "on"){
//button event
sendEvent(name: "pushed", value: "1", descriptionText: "Washer has finished.", isStateChange: true)
state.washerIsRunning = false
sendEvent(name: "washerState", value: "off", displayed: true)
} else {
name = "microwaveWatts"
if (value.toInteger() >= settings.microwaveRW.toInteger()){
//microwave is on
//if (state.microwaveIsRunning == false){
if (device.currentValue("microwaveState") == "off"){
//microwave is running
sendEvent(name: "pushed", value: "4", descriptionText: "Microwave is running.", isStateChange: true)
sendEvent(name: "microwaveState", value: "on", displayed: true)
state.microwaveIsRunning = true
} else {
//microwave is off
//if (state.microwaveIsRunning == true){
if (device.currentValue("microwaveState") == "on"){
//button event
sendEvent(name: "pushed", value: "2", descriptionText: "Microwave has finished.", isStateChange: true)
state.microwaveIsRunning = false
sendEvent(name: "microwaveState", value: "off", displayed: true)
if (state.washerIsRunning || state.microwaveIsRunning){
sendEvent(name: "switch", value: "on", descriptionText: "Laundry has started...", displayed: true)
} else {
sendEvent(name: "switch", value: "off", displayed: false)
//log.debug "mc3v- name: ${name}, value: ${value}, unit: ${str}"
return [name: name, value: value.toInteger(), unit: str, displayed: false]
def zwaveEvent(hubitat.zwave.Command cmd) {
// Handles all Z-Wave commands we aren't interested in
//log.debug "Unhandled event ${cmd}"
def configure() {
log.debug "configure()"
initialize()
def cmd = delayBetween([
//zwave.configurationV1.configurationSet(parameterNumber: 100, size: 4, scaledConfigurationValue:1).format(), //reset if not 0
//zwave.configurationV1.configurationSet(parameterNumber: 110, size: 4, scaledConfigurationValue: 1).format(), //reset if not 0
zwave.configurationV1.configurationSet(parameterNumber: 1, size: 2, scaledConfigurationValue: 60).format(), // assumed voltage
zwave.configurationV1.configurationSet(parameterNumber: 3, size: 1, scaledConfigurationValue: 0).format(), // Disable (=0) selective reporting
zwave.configurationV1.configurationSet(parameterNumber: 9, size: 1, scaledConfigurationValue: 10).format(), // Or by 10% (L1)
zwave.configurationV1.configurationSet(parameterNumber: 10, size: 1, scaledConfigurationValue: 10).format(), // Or by 10% (L2)
zwave.configurationV1.configurationSet(parameterNumber: 20, size: 1, scaledConfigurationValue: 1).format(), //usb = 1
zwave.configurationV1.configurationSet(parameterNumber: 101, size: 4, scaledConfigurationValue: 6912).format(),
zwave.configurationV1.configurationSet(parameterNumber: 111, size: 4, scaledConfigurationValue: 5).format() // Every 30 seconds
], 2000)
return cmd
def installed() {
configure()
def updated() {
configure()
def initialize() {
sendEvent(name: "numberOfButtons", value: 4)
def push(btnNumber) {
//log.debug btnNumber
def desc = bthNumber==1?"Washer has finished":"Microwave has finished"
sendEvent(name: "pushed", value: btnNumber, descriptionText: desc, isStateChange: true)
