I’m preparing to migrate from my C5 to a C8 Pro. I use the C5 for Zigbee devices and a few integrations. All my Zwave and most of my LAN/ Cloud integrations are on a C7. I also have most of my aqara zigbee devices on the C7 to keep them separate from the rest of the zigbee network.
I read the documentation on how to do the migration, but I also have seen a variety of posts from people running into problems with their zigbee network or various devices. Are there any other tips or things to do in advance to minimize issues? Or information I should be sure to have saved before shutting down the C5? Any settings to export or copy?
Do a local backup then do a restore of that backup. That ensures the database is clean. Then update the c5 and the c8 to the latest platform. Then do a shutdown and unplug power for 1 min and power back up. That ensures the radio is clean. Then do the migration. Follow this video. Note: After you do the migration backup from the c5, shutdown the c5 and unplug it. Then power up the c8 and finish the migration
Hi all - Wanted to come back and say I completed the migration and it went fairly well. I did get the "weak zigbee channel" message that others have talked about in other threads, due to being on channel 20. I have a few zigbee devices that lost connection after the migration. I have had to force them to rejoin. I had initially raised the power to 16, but after reading some threads, I put it back to the default of 8. I also ran the rebuild the zigbee network twice as suggested in some threads, although that didn't repair the disconnected devices by itself. Other than that, the migration went well.
I'm not sure why channel 20 gets this weak channel warning by default, as it was working fine before and seems to be okay now other than those few devices. My C7 is on channel 25 (used for problematic aqara devices that do better when isolated) and I also have a hue hub, so I didn't want to mess with the channel unnecessarily.
There has been enough of a support history with customers having Zigbee issues on channel 20 w/the C8P that HE staff determined that when customers report issues using 20, switching to another channel (25 or 15 are the most recommended) is suggested. I've used both 15 and 25 on my C8P's.
It can be a little confusing, as this is a YMMV situation (as is common w/HA) and some users don't have any issues using channel 20.
I think the Zigbee chipsets are different and the "motherboard" design is also different, so maybe one is more prone to interference or poor RX/TX on that particular channel.
@danabw is right, from what I have seen posted here, staff indicates that they seem to have more reported issues on ch20 on this hub model than other hub models. Or said another way, channels other than 20 perform better with this hub model for most users.
