Hi, I'd like to adjust my max heat temp but I can't find where to do this, it's currently 26.5 I want to lower it, many thanks for your help
I have a Honeywell T6 Pro. For this thermostat I have to change the max temp in the thermostat's menu.
I personally believe this is the best situation as the max heat saves me if the Hubitat goes off the reservation. I see you have a Min heat as well that is great mine does not have the min setting.
I'm using the advanced thermostat app so it doesn't have any other menus than the one in the app, it shows me what the max temp is but I can't see an option to change it sadly
I'm saying I believe you must go the physical thermostat and change that parameter through whatever menu system your thermostat has.
The advanced thermostat app turns non thermostat items into thermostat so I have a temp sensor which activates / deactivates a couple of relays as a thermostat would, so just to make sure I'm clear, there's no physical thermostat it's basically virtual so I can't do what you've suggested, if that makes sense ! I'm not a good at explaining myself lol
I totally misunderstood. I thought the Advanced thermostat you were referring was hardware based.
If you can't find it in the app''s menus you will have to reach out to the author of the app.
This all started because I couldn't find a zigbee thermostat that I could use standalone lol, it's no worries I honestly could have explained it better. I'll give it a go thankyou
