I am just migrating from ST to Hubitat and today finally I managed to migrate all devices in a single room.
Then I needed to add a rule for these devices and used the rule manager.
Basically a motion triggered action. But I could not find any trigger event like (changed 1 minute ago)
There are only "activated/changed/inactive" events.
I need some advanced events like "changed in last 2 minutes" etc.
Is there an advanced rule manager like Core for ST ?
I'm not sure exactly what you're trying to achieve, but to execute actions one minute after a change in a motion sensor, you could changed/inactive/active as your trigger and then have a delay statement as the first line of your actions.
@ilkeraktuna what exactly do you want to achieve? That's the most important question to ask. Often people asked to do things in a way because that's what they did on the "other" platform.
But often it's easier to do it's just worded differently.
Either way what is sounds like you want is a simple turn on with motion then turn off after the detector is in-active for X time. For that basic rules or motion lighting app will do that.
