@yototogblo, you got me to power up my hub again.
Did some testing with a barebones config and using a virtual switch and virtual button device.
Good news...I was able to replicate what you described.
Bad news..I have no idea how to fix it.
I forgot how long it took to reboot this bad boy..had to suffer through 10 plus reboots to confirm my tests
As another test, I also installed a user created Button Control device and guess what...it suffered from the same problem (i'm not going to mention the app but I will reach out to the dev so he knows he may receive similar complaints now that there are quite a few folks rebooting their hubs regularly).
I will reach out to HE support to see if they can point me in the right direction. More to come...
I have similar delay when I first press button 2 on my sylvania 2 button dimmer, I have another one of these button devices controlled by rule-4.0 and I don’t appear to have the same issue.
I see that I am using an old version of ABC though, maybe updating will solve some of my issue.
I tested with the latest version and the delays are there as well. As mentioned above, I'm also seeing this with another 3rd party app so we are waiting on feedback from support.
Interesting, I see this issue, too (confession: I suspect I wrote of of those "third-party apps" tested above) with a Pico on Rule 4.0. If I get patient enough, I might try rebooting my hub to see if I can reproduce this when I'm actually looking at the logs. Until you looked into this, I really just assumed it was some telnet-initialization issue with the Picos, but lately I've started to wonder if it's a per-app thing (maybe the first time that particular child or possibly child of any parent get run?).
Forced initialization on hub restart to avoid delays on "first activation". Thank you @ogiewon for the suggestion and thanks to Hubitat support for assisting and providing feedback.
Please note that you will need to open each mapping (child app) and click DONE for this change to take effect.
@yototogblo@timrudd12 Please see update above (and don't forget to open the child apps and hit Done like I did ).
There is still a small delay on first run but I haven't seen it go above 1s in my testing.
Thanks for the app! Found what might be a bug: my iBlinds window blind controllers don't show up under "Shades up/down/stop" in the ABC config when I try to configure one of my Pico remotes to control them. My MyControl Garage Door opener, however, does show up (not that I want to use the Pico for it
In the Rules engine, it's correct - iBlinds shows up as a shade device to be controlled and the garage door opener does not. I'm currently using Rules to configure my Pico however I'd prefer to use ABC as I use it for other stuff, plus I figured you'd want to know. Thanks again for the great app!
That's because that portion of the driver was written before there was a Window Shade capability (which I didnt know existed till now )
I could update this but it may break the config for some who use this to control "Door Control" devices. I will definitely update in some way, I just need to think of the best way to avoid disruption of existing configs. Thanks for pointing this out.
I guess I meant is there a way to increase and decrease the speed with a button push, cycle I assume increases until top then starts at lowest again. I expect it isn't something exposed again or you would have done it. I just have to hope they expose that in the drivers/HE like the reverse direction.
Great work on the app, this has solved a number of challenges I have been facing.
Is it possible to cycle through possible values for a device setting using ABC? Specifically, I'm using @dan.t's driver for the Hue Sync Box, and want to use a Pico remote to change inputs. I was thinking I would set pico buttons 2 & 4 to cycle forward or backwards through the various inputs, but I'm not seeing a good way to make that work.
I see an option to cycle through scenes, but hubitat scenes don't offer a way to set a specific setting such as the input, so I don't think that will work. What would be the best (not overly complicated) way to accomplish this?
I'm not familiar with it but I skimmed the code and looks like it only exposes a switch capability.
There is a command called setInput but there is no way for my app to access that command directly. I designed it to only utilize built in Hubitat commands and capabilities so it could be device agnostic...except in a couple of rare cases that benefit my personal apps and drivers ;).
@dan.t could probably provide suggestions based on what you are trying to accomplish...or possibly add a non-custom command that other apps can use to cycle the inputs.
I'm also wondering if there is a way to utilize Rule Machine to do this. I haven't used it in a LONG time but I know there was a way to execute a custom command. The trick would be in how to get it to cycle through them one at a time.
Theoretically, the driver could be easily extended to provide a cycleInput function. However, I am not sure if it will really work in real life. From what I have seen, the hue box takes it sweet time with responses to request, it is not snappy. Or at least mine isn’t... i think a person would give pretty annoyed with the delay not know if the “three” button presses were accepted and the box is just slow or if a button press was missed....
