Thanks for getting back @stephack.. I'm on site and can verify:
Have the latest:
ABC button mapping (child creator) v0.2.191105
Advanced Button Controller v0.2.190114
those are the only 2 instances of imported app code I have.
I let abc find the correct number of buttons (no override).. Of course when I import the 4button pico in, I have to ensure I set it from 5 to 4 buttons under Devices
When I say "turn everything off" I use: Switches->Turn Off->When Pushed. FWIW I can add 3 scenes and when I add the 4th button for all off.. it chokes.. or I can add 2 scenes for buttons 1-2 skip button 3 and add the Turn Off command to the 4th button. But if I try to add the 3rd scene to button 3 after that.. it chokes.
And lo and behold.. I run the mapping add sequence in debug and it worked just fine (sorry):
[app:86](http://192.168.1.24/logs#app86)2020-01-20 04:16:18.134 pm [debug](http://192.168.1.24/installedapp/configure/86)Kitchen Scene Mapping
[app:86](http://192.168.1.24/logs#app86)2020-01-20 04:16:18.130 pm [debug](http://192.168.1.24/installedapp/configure/86)INITIALIZED with settings: [collapseAll:true, buttonDevice:Kitchen Scene, logEnable:true, lightOn_1_pushed:[Kitchen Scene 1], lightOn_2_pushed:[Kitchen Scene 2], lightOn_3_pushed:[Kitchen Scene 3], lightOff_4_pushed:[Kitchen UnderCab Stove, Kitchen UnderCab Sink, Kitchen Entry Ceiling, Bar UnderCab, Bar Ceiling, Kitchen Ceiling]]
[app:86](http://192.168.1.24/logs#app86)2020-01-20 04:16:12.668 pm [debug](http://192.168.1.24/installedapp/configure/86)Device Type is now set to: Lutron Pico
[app:86](http://192.168.1.24/logs#app86)2020-01-20 04:15:01.931 pm [debug](http://192.168.1.24/installedapp/configure/86)Device Type is now set to: Lutron Pico
[app:86](http://192.168.1.24/logs#app86)2020-01-20 04:14:44.417 pm [debug](http://192.168.1.24/installedapp/configure/86)Device Type is now set to: Lutron Pico
[app:86](http://192.168.1.24/logs#app86)2020-01-20 04:14:27.138 pm [debug](http://192.168.1.24/installedapp/configure/86)Device Type is now set to: Lutron Pico
[app:86](http://192.168.1.24/logs#app86)2020-01-20 04:14:23.318 pm [debug](http://192.168.1.24/installedapp/configure/86)Device Type is now set to: Lutron Pico
[app:86](http://192.168.1.24/logs#app86)2020-01-20 04:13:58.479 pm [debug](http://192.168.1.24/installedapp/configure/86)Device Type is now set to: Lutron Pico
[app:86](http://192.168.1.24/logs#app86)2020-01-20 04:13:48.805 pm [debug](http://192.168.1.24/installedapp/configure/86)
[app:86](http://192.168.1.24/logs#app86)2020-01-20 04:13:48.797 pm [debug](http://192.168.1.24/installedapp/configure/86)INITIALIZED with settings: [collapseAll:true, buttonDevice:Kitchen Scene, logEnable:true]
Sorry for the confusion @stephack, I went to generate a debug log with the error in it by generating a new Pico device mapping from scratch. When I did, it worked fine.. but the day before no matter how many times I tried it would error on the 4th button. I will send the log when/if it happens again. Thanks for your help!
Best,
Andrew
Glad to hear that. If it does happen again, please try to remember the exact steps it took to recreate and when precisely the error occurs in the sequence of steps.
You can submit the PR but it may take a while for me to accept. I dont have a hub in production at the moment to properly test any changes and I also have a couple of feature requests to get added. I will do my best to get your changes incorporated as time permits.
I use ABC to turn off my Hue bulbs from my Inovelli ZWave light switches. Also, I reboot my hub every other day to cut back on the slowdowns.
I've noticed that ABC takes a while to respond to button presses after a restart. Typically, my hue bulbs turn on or off in about 800ms after the switch is pushed. However, right after a restart, it typically takes about 7s. It almost feels like the app doesn't actually get initialized until the first button press.
Please help look into this. I created the same automation using Hubitat Simple Lighting and it doesn't have the same issue.
I still haven't had the time to put one of my Hubitat hubs back into production, so I cant test your theory on my end yet. However, I'm pretty sure wasn't seeing your issue when I was using HE a few months ago.
A few questions:
Is this a recent problem?
What firmware version are you on?
How long after the reboot are you testing? It takes a while after a reboot for the meshes to truly settle in.
Can you replicate the problem consistently?
If you look at the logs, it should provide clues as to where the delay is occurring. Share a screenshot of the logs when this occurs if you can.
Please bare with me as I'll be trying to assist blindly until I can get my hub back in production.
This time is actually one of the fastest I've seen of it responding after a restart. It typically takes about 7s. I just did the latest update also though so maybe that helped.
Also, the delay is always between the switch sending the central scene (or the button press) and the ABC debug app picking it up.
I may be misreading the logs above, but it looks fine.
Assuming that dev23 is your inovelli switch and app28 is the ABC instance associated with it, then it's taking 500ms to respond to the CentralSceneNotification. It then takes another 600ms or so for Ben and P lights to actually turn on (which is not in the control of ABC...it can only send the command it is configured to).
No, you're right in this case. That's why I mentioned that it was much faster than typical and was wondering if that had more to do with the latest update that I just installed. However, even in this case, you can see that the next 2 times I toggled the switch, it only took 300ms (vs 530ms) for ABC to respond.
I just tried rebooting the hub again and here are the new results. As you can see, it took about 2.6s for ABC to register the button press right after the restart and then only 200ms after that.
Thanks for the update @yototogblo. @bravenel@chuck.schwer any thoughts on what was described above? I don't know what is considered normal for the first time an app is initialized so I can't say if my app is outside of what is to be expected. I would appreciate any feedback you could provide.
Tldr for issue
after a hub restart the ABC app takes anywhere between 500ms and 7s to process a button event. Thereafter it operates at an expected speed.
I am currently unable to do a comparison on my hub as it is offline.
I got an answer from Bruce but before I really thought out your request. I assume you are asking to only have the button work between a certain time and sunset/sunrise. This might be trickier than I thought initially. Will have to think it through.
