Apologies if this is in the wrong spot. Would it be possible to add small column for device status when in tile/list mode?
I would like to be able to glance at a status of my devices (on/off, percentage for dimmers/fans, open/closed) when going through the list. I have a few Virtual Devices that trigger rules, and would like to be able to tell which one is currently on, without going into it's properties, then coming back out.
I feel torn myself.... I can understand the convenience of having it available in some of the internal pages (though I can't say I have utilised the tile view myself). I can imagine that there is an assumption applied to the presentation of a tile in a dashboard about which attribute to use when reflecting the "state" of the device, used when defining the different foreground and background colors, so I could imagine the same logic could be applied to the Device listing.
It does get a little murky once you step into some of the device types (drivers) that support multiple capabilities, typically Community-developed ones, where you may have something like a devices for a weather station implementing temperature, humidity, perhaps a battery reading as well, plus many other sensor readings. In a dashboard example you can choose a template to apply, but that may be a little more problematic to do consistently for each type of custom device. The only way I could see that working for Community developed device drivers would be the developer identifying or allowing the user to select a dominant capability, such as a temperature reading as being the dominant attribute in a weather station device.
So while not impossible, there would be some details to iron out. I suspect, given the flexibility of a dashboard, that would likely be where Hubitat staff would direct you to focus your efforts in terms of seeing at a glance the current status of devices.
