add 4 Ecolink z wave plus sensor. trying to add more. but hubitat cant find them . I'm in the same spot where I added the other ones
It's been a while since I messed with my Ecolink contact sensors. How about removing and then replacing the battery?
I have many Ecolink sensors, although most of them I use as dry contact relays. velvetfoot is correct, remove the battery for 15 seconds or so, then re-insert. "Exclude" first, then "include" into the system using the same process. Mine have been very reliable.
Mine too. Long lasting battery too, even though it's a little special. Plus the aux contacts are handy once in a while.
they brand new out the box . all of them . just start my smart home adventure
they are new out the box . 4 were found the rest it cant find, when you exclude them should the device . show up ?
i unplugged hub now its working
You should use the shutdown option first and then uplug when it says it's safe to.
Please shut down before unplugging or you run the risk of corrupting the database. That said, can you post your z-wave details page in its entirety so we can confirm you don't have any issues there?
