I see a lot of examples of people posting dashboards with TEXT fields, either as a tile or not, appearing. (typically showing room sorting or lists)
I have no idea how to add this.
Any helpful hints would be appreciated.
Search for "text" as the Template and then enter what you want in the 'Text' input section. You can make the tiles background transparent in the templates section, or via CSS, if you do not want to see it.
Thanks so much. I just figured this out before you replied.
I had no idea you could use the templates without having a device attached. Makes a BIG difference in my dashboard building.
