Adding new Global Variables to Legacy Dashboard
C-8 Pro running 2.4.2.160. Nothing new – I’m confused - again. I thought just a little while back the name of the game was to not use connectors for hub variables. So I redid my dashboards to use the global variables directly and deleted all the connectors. All my dashboards work fine that way except now I wanted to add a new global variable to a dashboard - and I now can’t find a way to do that – except by making a connector to be a device which then can be added. It appears that ONLY devices can be added to a dashboard, not variables. What happened to being able to add global variables as well as devices to a legacy dashboard? Is bringing back connectors really the way to go now?
You should be able to add your variables using this option. I have several dashboard with many global variables.
I don't get that option using Firefox or Edge as web browsers on a PC. Nor using the iOS app. I have several global variables already in dashboards and working. But I can't seem to add any new ones - not sure what platform version this happened on but with the past few months.
Yes, but before that list is available for Variables, you have to populate it - or assign the global variables you want to use in a particular dashboard. That's the part that I am now missing - it used to be there along with devices on the Dashboard app page, but now only Devices are allowed to be assigned or edited to a legacy dashboard.
It's on this device assignment page that is now missing Global Variables
Need to go to the Hubitat Dashboards app, select the child dashboard app you're interested in and then scroll until you get underneath the devices:
Sorry, when I do that, it only shows the variables that I have previously assigned to my dashboard under earlier, but recent, firmware. It does NOT show ALL my global variables to pick from. What I want to do is add more variables to that list - and as far as I knew, that was with the dashboard app. What am I missing?
If you want to create new variables it's under Settings Tab | Hub Variables
No, sorry, I know how to make variables and have quite a few. But if you will, please add a NEW hub variable - and then try to add it to a legacy dashboard. It's that 2nd part I don't have the ability to do anymore - unless I make it a device aka connector. And I thought that wasn't the way to go.
Or add a global variable to a brand new legacy dashboard...
Thanks @thebearmay for picking this up. I got caught up working on another project.
Clicking the dashboard "Open App" was the trick. It's not where I expected it. Thanks!!
