Adding DoorSense To Z-Wave Yale Driver
Don't know if you're still trying to get DoorSense working. I got obsessed with it and heavily modified the driver that you linked. It reports door sense events now and registers the door as a contact sensor so existing code can work with it. The lock codes is updated to work with Lock Code Manager as well. I apologize upfront for the coding and commenting quality, especially the commenting. This is just a hobby for me and I've never programmed in an organized setting.
 * 	Z-Wave Lock
 *  Derivative Work Copyright 2025 Joe McNamee
 *  (Previous: Derivative Work Copyright 2019 Hans Andersson, Copyright 2024 William Siggson)
 *  Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
 *  in compliance with the License. You may obtain a copy of the License at:
 *      http://www.apache.org/licenses/LICENSE-2.0
 *  Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
 *  on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
 *  for the specific language governing permissions and limitations under the License.
  *  Joe McNamee modified code to work properly with doorsense and enable contact sensor
  *  Also brought event handling to current standard (sendevent vs createevent percolation), corrected lock code support for lock code manager
metadata {
	definition (name: "Yale Assure Z-Wave Lock", namespace: "Mrjoemac", author: "Joe McNamee") {
		capability "Actuator"
		capability "Lock"
		capability "Polling"
		capability "Refresh"
		capability "ContactSensor"
		capability "Lock Codes"
		capability "Battery"
		capability "Health Check"
		capability "Configuration"
		command "reloadCodes", [
			[name: "positions", type: "STRING", description: "Comma separated list: individual positions or ranges (e.g. 1,3,5-7). Also ALL for all positions."]
		fingerprint mfr:"0129", prod:"8002", model:"0600", deviceJoinName: "Yale Assure Lock" //YRD416, YRD426, YRD446
		fingerprint mfr:"0129", prod:"8004", model:"0600", deviceJoinName: "Yale Assure Lock Push Button Deadbolt" //YRD216
		fingerprint mfr:"0129", prod:"800B", model:"0F00", deviceJoinName: "Yale Assure Keypad Lever Door Lock" // YRL216-ZW2
		fingerprint mfr:"0129", prod:"800C", model:"0F00", deviceJoinName: "Yale Assure Touchscreen Lever Door Lock" // YRL226-ZW2
		fingerprint mfr:"0129", prod:"8002", model:"1000", deviceJoinName: "Yale Assure Lock" //YRD-ZWM-1
		fingerprint mfr:"0129", prod:"8107", model:"1000", deviceJoinName: "Yale Assure Lock 2 Touch" //YRD450-F-ZW3-619
import hubitat.zwave.commands.doorlockv1.*
import hubitat.zwave.commands.usercodev1.*
 * Called on app installed
def installed() {
	// Device-Watch pings if no device events received for 1 hour (checkInterval)
	sendEvent(name: "checkInterval", value: 1 * 60 * 60, displayed: false, data: [protocol: "zwave", hubHardwareId: device.hub.hardwareID, offlinePingable: "1"])
	scheduleInstalledCheck()
 * Verify that we have actually received the lock's initial states.
 * If not, verify that we have at least requested them or request them,
 * and check again.
def scheduleInstalledCheck() {
	runIn(120, installedCheck)
def installedCheck() {
	if (device.currentState("lock") && device.currentState("battery")) {
		unschedule("installedCheck")
	} else {
		// We might have called updated() or configure() at some point but not have received a reply, so don't flood the network
		if (!state.lastLockDetailsQuery || secondsPast(state.lastLockDetailsQuery, 2 * 60)) {
			def actions = updated()
			if (actions) {
				sendHubCommand(actions.toHubAction())
 * Called on app uninstalled
def uninstalled() {
	def deviceName = device.displayName
	log.trace "[DTH] Executing 'uninstalled()' for device $deviceName"
	sendEvent(name: "lockRemoved", value: device.id, isStateChange: true, displayed: false)
 * Executed when the user taps on the 'Done' button on the device settings screen. Sends the values to lock.
 * @return hubAction: The commands to be executed
def updated() {
	def hubAction = null
	try {
		def cmds = []
		if (!device.currentState("lock") || !device.currentState("battery") || !state.configured) {
			log.debug "Returning commands for lock operation get and battery get"
			if (!state.configured) {
				doConfigure()
			refresh()
			cmds << secure(zwave.userCodeV1.usersNumberGet())
			if (!state.MSR) {
				cmds << zwave.manufacturerSpecificV1.manufacturerSpecificGet().format()
			if (!state.fw) {
				cmds << zwave.versionV1.versionGet().format()
			executeCommands(delayBetween(cmds, 30*1000))
	} catch (e) {
		log.warn "updated() threw $e"
 * Configures the device to settings needed by SmarthThings at device discovery time
def configure() {
	log.trace "[DTH] Executing 'configure()' for device ${device.displayName}"
	doConfigure()
 * Returns the list of commands to be executed when the device is being configured/paired
def doConfigure() {
	log.trace "[DTH] Executing 'doConfigure()' for device ${device.displayName}"
	state.configured = true
	def cmds = []
	cmds << secure(zwave.doorLockV1.doorLockOperationGet())
	cmds << secure(zwave.batteryV1.batteryGet())
	cmds = delayBetween(cmds, 30*1000)
	executeCommands(cmds)		// run configuration commands
	state.lastLockDetailsQuery = now()
	log.debug "Do configure returning with commands := $cmds"
def zwaveEvent(hubitat.zwave.commands.supervisionv1.SupervisionGet cmd) {
    log.trace "[DTH] Executing 'zwaveEvent(hubitat.zwave.commands.supervisionv1.SupervisionGet cmd)' with cmd = $cmd"
    hubitat.zwave.Command encapCmd = cmd.encapsulatedCommand(commandClassVersions) // we defined commandClassVersions above
    if (encapCmd) {
        zwaveEvent(encapCmd)
    sendHubCommand(new hubitat.device.HubAction(zwaveSecureEncap(zwave.supervisionV1.supervisionReport(sessionID: cmd.sessionID, reserved: 0, moreStatusUpdates: false, status: 0xFF, duration: 0).format()), hubitat.device.Protocol.ZWAVE))
 * Responsible for parsing incoming device messages to generate events
 * @param description: The incoming description from the device
 * @return result: The list of events to be sent out
	log.trace "[DTH] Executing 'parse(String description)' for device ${device.displayName} with description = $description"
	def result = null
	if (description.startsWith("Err")) {
//        log.debug "********************** Err "
		if (state.sec) {
			sendEvent(descriptionText:description, isStateChange:true, displayed:false)
		} else {
			sendEvent(
					descriptionText: "This lock failed to complete the network security key exchange. If you are unable to control it via SmartThings, you must remove it from your network and add it again.",
					eventType: "ALERT",
					value: "failed",
					displayed: true,
	} else {
//        log.debug "*** description *** = " + description
		def cmd = zwave.parse(description, [ 0x98: 1, 0x62: 1, 0x63: 1, 0x71: 2, 0x72: 2, 0x80: 1, 0x85: 2, 0x86: 1 ])
//        log.debug "*** cmd *** = " + cmd
		if (cmd) {
			result = zwaveEvent(cmd)
            log.debug "Parsed ${cmd} to ${result.inspect()}"
	log.info "[DTH] parse() - returning result=$result"
	return result
 * Responsible for parsing ConfigurationReport command
 * @param cmd: The ConfigurationReport command to be parsed
 * @return The event(s) to be sent out
def zwaveEvent(hubitat.zwave.commands.configurationv2.ConfigurationReport cmd) {
	log.trace "[DTH] Executing 'zwaveEvent(hubitat.zwave.commands.configurationv2.ConfigurationReport cmd)' with cmd = $cmd"
	return null
 * Responsible for parsing SecurityMessageEncapsulation command
 * @param cmd: The SecurityMessageEncapsulation command to be parsed
def zwaveEvent(hubitat.zwave.commands.securityv1.SecurityMessageEncapsulation cmd) {
	log.trace "[DTH] Executing 'zwaveEvent(hubitat.zwave.commands.securityv1.SecurityMessageEncapsulation)' with cmd = $cmd"
	def encapsulatedCommand = cmd.encapsulatedCommand([0x62: 1, 0x71: 2, 0x80: 1, 0x85: 2, 0x63: 1, 0x98: 1, 0x86: 1])
	if (encapsulatedCommand) {
		zwaveEvent(encapsulatedCommand)
 * Responsible for parsing NetworkKeyVerify command
 * @param cmd: The NetworkKeyVerify command to be parsed
def zwaveEvent(hubitat.zwave.commands.securityv1.NetworkKeyVerify cmd) {
	log.trace "[DTH] Executing 'zwaveEvent(hubitat.zwave.commands.securityv1.NetworkKeyVerify)' with cmd = $cmd"
	sendEvent(name:"secureInclusion", value:"success", descriptionText:"Secure inclusion was successful", isStateChange: true)
 * Responsible for parsing SecurityCommandsSupportedReport command
 * @param cmd: The SecurityCommandsSupportedReport command to be parsed
def zwaveEvent(hubitat.zwave.commands.securityv1.SecurityCommandsSupportedReport cmd) {
	log.trace "[DTH] Executing 'zwaveEvent(hubitat.zwave.commands.securityv1.SecurityCommandsSupportedReport)' with cmd = $cmd"
	state.sec = cmd.commandClassSupport.collect { String.format("%02X ", it) }.join()
	if (cmd.commandClassControl) {
		state.secCon = cmd.commandClassControl.collect { String.format("%02X ", it) }.join()
	sendEvent(name:"secureInclusion", value:"success", descriptionText:"Lock is securely included", isStateChange: true)
 * Responsible for parsing DoorLockOperationReport command
 * @param cmd: The DoorLockOperationReport command to be parsed
def zwaveEvent(DoorLockOperationReport cmd) {
	log.trace "[DTH] Executing 'zwaveEvent(DoorLockOperationReport)' with cmd = $cmd"
	unschedule("followupStateCheck")
	unschedule("stateCheck")
	// DoorLockOperationReport is called when trying to read the lock state or when the lock is locked/unlocked from the DTH or the smart app
//log.debug "****** cmd ****** = " + cmd
	def map = [ name: "lock" ]
	map.data = [ lockName: device.displayName ]
	if (cmd.doorLockMode == 0xFF) {
		map.value = "locked"
		map.descriptionText = "Locked"
	} else if (cmd.doorLockMode >= 0x40) {
		map.value = "unknown"
		map.descriptionText = "Unknown state"
	} else if (cmd.doorLockMode == 0x01) {
		map.value = "unlocked with timeout"
		map.descriptionText = "Unlocked with timeout"
	}  else {
		map.value = "unlocked"
		map.descriptionText = "Unlocked"
		if (state.assoc != zwaveHubNodeId) {
			def cmds = []
			cmds << secure(zwave.associationV1.associationSet(groupingIdentifier:1, nodeId:zwaveHubNodeId))
			cmds << zwave.associationV1.associationSet(groupingIdentifier:2, nodeId:zwaveHubNodeId)
			cmds << secure(zwave.associationV1.associationGet(groupingIdentifier:1))
	sendEvent(map)
def delayLockEvent(data) {
	log.debug "Sending cached lock operation: $data.map"
	sendEvent(data.map)
 * Responsible for parsing AlarmReport command
 * @param cmd: The AlarmReport command to be parsed
def zwaveEvent(hubitat.zwave.commands.alarmv2.AlarmReport cmd) {
	log.trace "[DTH] Executing 'zwaveEvent(hubitat.zwave.commands.alarmv2.AlarmReport)' with cmd = $cmd"
	if (cmd.zwaveAlarmType == 6) {
		handleAccessAlarmReport(cmd)
	} else if (cmd.zwaveAlarmType == 7) {
		handleBurglarAlarmReport(cmd)
	} else if(cmd.zwaveAlarmType == 8) {
		handleBatteryAlarmReport(cmd)
	} else {
		handleAlarmReportUsingAlarmType(cmd)
	log.debug "[DTH] zwaveEvent(hubitat.zwave.commands.alarmv2.AlarmReport) returning with result = $result"
 * Responsible for handling Access AlarmReport command
private def handleAccessAlarmReport(cmd) {
	log.trace "[DTH] Executing 'handleAccessAlarmReport' with cmd = $cmd"
	def result = []
	def map = null
	def codeID, changeType, lockCodes, codeName
	lockCodes = loadLockCodes()
	if (1 <= cmd.zwaveAlarmEvent && cmd.zwaveAlarmEvent < 10) {
		map = [ name: "lock", value: (cmd.zwaveAlarmEvent & 1) ? "locked" : "unlocked" ]
	switch(cmd.zwaveAlarmEvent) {
		case 1: // Manually locked
			map.descriptionText = "Locked manually"
			map.data = [ method: (cmd.alarmLevel == 2) ? "keypad" : "manual" ]
            sendEvent(name: "lock", value: "locked", descriptionText: "Locked manually", isStateChange: true)
			break
		case 2: // Manually unlocked
			map.descriptionText = "Unlocked manually"
			map.data = [ method: "manual" ]
            sendEvent(name: "lock", value: "unlocked", descriptionText: "Unlocked manually", isStateChange: true)
			break
		case 3: // Locked by command
			map.data = [ method: "command" ]
            sendEvent(name: "lock", value: "locked", descriptionText: "Locked by command", isStateChange: true)
			break
		case 4: // Unlocked by command
            sendEvent(name: "lock", value: "unlocked", descriptionText: "Unlocked by command", isStateChange: true)
			break
		case 5: // Locked with keypad
			if (cmd.eventParameter || cmd.alarmLevel) {
				codeID = readCodeSlotId(cmd)
				codeName = getCodeName(lockCodes, codeID)
				map.descriptionText = "$deviceName locked by \"$codeName\""
				map.data = [ codeId: codeID as String, usedCode: codeID, codeName: codeName, method: "keypad" ]
                sendEvent(name: "lock", value: "locked", descriptionText: "Locked by $codeName", isStateChange: true)
			} else {
				map.data = [ method: "keypad" ]
                sendEvent(name: "lock", value: "locked", descriptionText: "Locked by keypad", isStateChange: true)
			break
		case 6: // Unlocked with keypad
				map.descriptionText = "Unlocked by \"$codeName\""
                sendEvent(name: "lock", value: "unlocked", descriptionText: "Unlocked by $codeName", isStateChange: true)
			break
		case 7:
			map = [ name: "lock", value: "unknown", descriptionText: "Unknown state" ]
			break
		case 8:
			break
		case 9: // Auto locked
			map = [ name: "lock", value: "locked", data: [ method: "auto" ] ]
			map.descriptionText = "Auto locked"
            sendEvent(name: "lock", value: "locked", descriptionText: "Auto locked", isStateChange: true)
			break
		case 0xA:
			map.data = [ method: "auto" ]
			break
		case 0xB:
			break
		case 0xC: // All user codes deleted
			map = [ name: "codeChanged", value: "all deleted", descriptionText: "Deleted all user codes", isStateChange: true ]
			map.data = [notify: true, notificationText: "Deleted all user codes in $deviceName at ${location.name}"]
			sendLockCodesEvent([:])
			break
		case 0xD: // User code deleted
				codePosition = readCodeSlotId(cmd)
				return handleUserCodeDeleted(codePosition)
			break
		case 0xE: // Master or user code changed/set
				log.debug("code changed from 0xE position $codePosition")
				return handleUserCodeChanged(codePosition)
			break
		case 0xF: // Duplicate Pin-code error
				return handleUserCodeDuplicate(codePosition)
			break
		case 0x10: // Tamper Alarm
		case 0x13:
			map = [ name: "tamper", value: "detected", descriptionText: "Keypad attempts exceed code entry limit", isStateChange: true, displayed: true ]
			break
		case 0x11: // Keypad busy
			map = [ descriptionText: "Keypad is busy" ]
			break
		case 0x12: // Master code changed
			map = [ name: "codeChanged", value: "0 set", descriptionText: "master code changed", isStateChange: true ]
			map.data = [ notify: true, notificationText: "master code changed in $deviceName at ${location.name}" ]
			break
        case 22:
        case 23:
            return handleDoorSenseReport(cmd)
		case 0xFE:		// delegating it to handleAlarmReportUsingAlarmType
		default:
			return handleAlarmReportUsingAlarmType(cmd)
	if (map) {
		if (map.data) {
			map.data.lockName = deviceName
		} else {
			map.data = [ lockName: deviceName ]
		sendEvent(map)
private def handleAllUserCodesDeleted() {
	log.trace "[DTH] Executing 'handleAllUserCodesDeleted' for device ${device.displayName}"
private def handleUserCodeDeleted(codePosition) {
	log.trace "[DTH] Executing 'handleUserCodeDeleted' for device ${device.displayName}"
	name = lockCodes[codePosition.toString()].name
	def map = [ name: "codeChanged", value: "$codePosition deleted", descriptionText: "User code for $name at $codePosition deleted", isStateChange: true, data: [isCodeDuplicate: true] ]
	lockCodes.remove(codePosition.toString())
	sendLockCodesEvent(lockCodes)
	sendEvent(map)
private def handleUserCodeChanged(codePosition) {
	log.trace "[DTH] Executing 'handleUserCodeChanged' for device ${device.displayName}"
	log.debug("codes: $lockCodes")
	log.debug("codePosition: $codePosition")
	def map = [ name: "codeChanged", isStateChange: true, value: "$codePosition changed", descriptionText: "Code for $name at position $codePosition changed" ]
	if(!isMasterCode(codeID)) {
		validateLockCode(codePosition)
	} else {
		map.descriptionText = "${getStatusForDescription('set')} \"$codeName\""
		map.data.notificationText = "${getStatusForDescription('set')} \"$codeName\" in $deviceName at ${location.name}"
	sendEvent(map)
private def handleUserCodeDuplicate(codePosition) {
	log.trace "[DTH] Executing 'handleUserCodeDuplicate' for device ${device.displayName}"
	def map = [ name: "codeChanged", value: "$codePosition failed, duplicate pin", descriptionText: "User code is duplicate and not added", isStateChange: true, data: [isCodeDuplicate: true] ]
	def duplicateCode = lockCodes[codePosition.toString()].code
	def positionToDelete = null
	lockCodes.each{ k, v -> if (v.code == duplicateCode) {positionToDelete = k} }
	if (positionToDelete) {
		name = lockCodes[positionToDelete].name
		map.value = "$positionToDelete failed, duplicate pin"
		map.descriptionText = "code for $name at position $positionToDelete failed, duplicate pin"
		lockCodes.remove(positionToDelete)
	sendEvent(map)
 * Responsible for handling DoorSense events
 * @return: does not return data
private def handleDoorSenseReport(cmd) {
    log.trace "[DTH] Executing 'handleDoorSenseReport' with cmd = $cmd"
    def map = [ name: "contact", value: "open", descriptionText: "", isStateChange: true ]
    switch (cmd.alarmLevel) {
        case 0:  // Door is open
            map.value = "open"
            map.descriptionText = "Door opened"
            sendEvent(map)
            break;
        case 1:  // Door is closed
            map.value = "closed"
            map.descriptionText = "Door closed"
            sendEvent(map)
            break;
        case 2:  // Door Propped (door open for longer than configurable door propped open)
            map.value = "open"
            map.descriptionText = "Door propped opened"
            sendEvent(map)
            break;
        default:
            log.trace "NotificationReport Error (Received non supported DoorSense alarmLevel from lock)"
            break;
 * Responsible for handling Burglar AlarmReport command
private def handleBurglarAlarmReport(cmd) {
	log.trace "[DTH] Executing 'handleBurglarAlarmReport' with cmd = $cmd"
	def map = [name: "tamper", isStateChange: true, data: [ lockName: device.displayName ] ]
	switch (cmd.zwaveAlarmEvent) {
		case 0:
			map.value = "clear"
			map.descriptionText = "Tamper alert cleared"
			break
		case 1:
		case 2:
			map.value = "detected"
			map.descriptionText = "Intrusion attempt etected"
			break
		case 3:
			map.descriptionText = "Covering removed"
			break
		case 4:
			map.descriptionText = "Invalid code"
			break
		default:
	sendEvent(map)
 * Responsible for handling Battery AlarmReport command
private def handleBatteryAlarmReport(cmd) {
	log.trace "[DTH] Executing 'handleBatteryAlarmReport' with cmd = $cmd"
		case 0x01: //power has been applied, check if the battery level updated
			executeCommand(secure(zwave.batteryV1.batteryGet()))
			break;
		case 0x0A:
			sendEvent(name: "battery", value: 1, descriptionText: "Battery level critical", displayed: true, data: [ lockName: deviceName ])
			break
		case 0x0B:
			sendEvent(name: "battery", value: 0, descriptionText: "Battery too low to operate lock", isStateChange: true, displayed: true, data: [ lockName: deviceName ])
			break
		default:
 * Responsible for handling AlarmReport commands which are ignored by Access & Burglar handlers
private def handleAlarmReportUsingAlarmType(cmd) {
	log.trace "[DTH] Executing 'handleAlarmReportUsingAlarmType' with cmd = $cmd"
	def result = []
	def map = null
	def codeID, lockCodes, codeName
	switch(cmd.alarmType) {
		case 9:
		case 17:
			break
		case 16: // Note: for levers this means it's unlocked, for non-motorized deadbolt, it's just unsecured and might not get unlocked
		case 19: // Unlocked with keypad
			map = [ name: "lock", value: "unlocked" ]
			if (cmd.alarmLevel != null) {
				map.isStateChange = true // Non motorized locks, mark state changed since it can be unlocked multiple times
			break
		case 18: // Locked with keypad
			map = [ name: "lock", value: "locked" ]
			map.descriptionText = "Locked by \"$codeName\""
			break
		case 21: // Manually locked
			map = [ name: "lock", value: "locked", data: [ method: (cmd.alarmLevel == 2) ? "keypad" : "manual" ] ]
			break
		case 22: // Manually unlocked
			map = [ name: "lock", value: "unlocked", data: [ method: "manual" ] ]
			break
		case 23:
			break
		case 24: // Locked by command
			map = [ name: "lock", value: "locked", data: [ method: "command" ] ]
			break
		case 25: // Unlocked by command
			map = [ name: "lock", value: "unlocked", data: [ method: "command" ] ]
			break
		case 26:
			break
		case 27: // Auto locked
			break
		case 32: // All user codes deleted
			break
		case 33: // User code deleted
			break
		case 38: // Non Access
			map = [ descriptionText: "A Non Access Code was entered at the lock", isStateChange: true ]
			break
		case 13:
		case 112: // Master or user code changed/set
			log.debug("code changed from 112 position $codePosition")
			break
		case 34:
		case 113: // Duplicate Pin-code error
			return handleDuplicateUserCode(codePosition)
			break
		case 130:  // Batteries replaced
			map = [ descriptionText: "Batteries replaced", isStateChange: true ]
			break
		case 131: // Disabled user entered at keypad
			map = [ descriptionText: "Code ${cmd.alarmLevel} is disabled", isStateChange: false ]
			break
		case 161: // Tamper Alarm
			if (cmd.alarmLevel == 2) {
				map = [ name: "tamper", value: "detected", descriptionText: "Front escutcheon removed", isStateChange: true ]
			} else {
			break
		case 167: // Low Battery Alarm
			if (!state.lastbatt || now() - state.lastbatt > 12*60*60*1000) {
				map = [ descriptionText: "Battery low", isStateChange: true ]
			} else {
				map = [ name: "battery", value: device.currentValue("battery"), descriptionText: "Battery low", isStateChange: true ]
			break
		case 168: // Critical Battery Alarms
			map = [ name: "battery", value: 1, descriptionText: "Battery level critical", displayed: true ]
			break
		case 169: // Battery too low to operate
			map = [ name: "battery", value: 0, descriptionText: "Battery too low to operate lock", isStateChange: true, displayed: true ]
			break
		default:
			map = [ displayed: false, descriptionText: "Alarm event ${cmd.alarmType} level ${cmd.alarmLevel}" ]
			break
	if (map) {
		if (map.data) {
		} else {
		sendEvent(map)
 * refactoring
 * Responsible for parsing UserCodeReport command
 * @param cmd: The UserCodeReport command to be parsed
def zwaveEvent(UserCodeReport cmd) {
	log.trace "[DTH] Executing 'zwaveEvent(UserCodeReport)' with userIdentifier: ${cmd.userIdentifier} and status: ${cmd.userIdStatus} and full cmd $cmd"
	def result = []
	// cmd.userIdentifier seems to be an int primitive type
	def codePosition = cmd.userIdentifier.toString()
	def lockCodes = loadLockCodes()
	def map = [ name: "codeChanged", isStateChange: true ]
	def userIdStatus = cmd.userIdStatus
	if (userIdStatus == UserCodeReport.USER_ID_STATUS_OCCUPIED ||
			(userIdStatus == UserCodeReport.USER_ID_STATUS_STATUS_NOT_AVAILABLE && cmd.user)) {
		log.trace("User code for position $codePosition is occupied")
		if (!lockCodes.containsKey(codePosition) || lockCodes[codePosition].code != cmd.userCode.toString()) {
			log.trace("User code for position $codePosition is different or non-existent")
			lockCodes[codePosition].code = cmd.userCode.toString()
			map.value = "code updated for $codePosition"
			map.descriptionText = "Code for ${lockCodes[codePosition].name} at position $codePosition updated"
		// code is already set
	} else {
		// We are using userIdStatus here because codeID = 0 is reported when user tries to set programming code as the user code
		// code is not set
		log.trace("User code for position $codePosition is not set, removing from lockCodes")
		lockCodes.remove(codePosition)
	if (state.checkCode == codePosition.toInteger()) {
		reloadList = state.codeReloadList
		if (codePosition.toInteger() == reloadList.first()) {
			reloadList = reloadList.drop(1)
			state.codeReloadList = reloadList
		if (reloadList.size() > 0) {
			state.checkCode = reloadList.first()
			executeCommand(secure(zwave.userCodeV1.userCodeGet(userIdentifier:state.checkCode.toInteger())))
		} else {
			state.checkCode = null
			state.codeReloadList = null
			sendEvent(name: "reloadCodes", value: "reloading complete", descriptionText: "Code reload complete")
			log.trace("Code reload complete")
 * Responsible for parsing UsersNumberReport command
 * @param cmd: The UsersNumberReport command to be parsed
def zwaveEvent(UsersNumberReport cmd) {
	log.trace "[DTH] Executing 'zwaveEvent(UsersNumberReport)' with cmd = $cmd"
	sendEvent(name: "maxCodes", value: cmd.supportedUsers, displayed: false)
 * Responsible for parsing AssociationReport command
 * @param cmd: The AssociationReport command to be parsed
def zwaveEvent(hubitat.zwave.commands.associationv2.AssociationReport cmd) {
	log.trace "[DTH] Executing 'zwaveEvent(hubitat.zwave.commands.associationv2.AssociationReport)' with cmd = $cmd"
	if (cmd.nodeId.any { it == zwaveHubNodeId }) {
		state.remove("associationQuery")
		state["associationQuery"] = null
		sendEvent(descriptionText: "Is associated")
		state.assoc = zwaveHubNodeId
		if (cmd.groupingIdentifier == 2) {
			executeCommand(secure(zwave.associationV1.associationRemove(groupingIdentifier:1, nodeId:zwaveHubNodeId)))
	} else if (cmd.groupingIdentifier == 1) {
		executeCommand(secure(zwave.associationV1.associationSet(groupingIdentifier:1, nodeId:zwaveHubNodeId)))
	} else if (cmd.groupingIdentifier == 2) {
		executeCommand(secure(zwave.associationV1.associationSet(groupingIdentifier:2, nodeId:zwaveHubNodeId)))
 * Responsible for parsing TimeGet command
 * @param cmd: The TimeGet command to be parsed
def zwaveEvent(hubitat.zwave.commands.timev1.TimeGet cmd) {
	log.trace "[DTH] Executing 'zwaveEvent(hubitat.zwave.commands.timev1.TimeGet)' with cmd = $cmd"
	def result = []
	def now = new Date().toCalendar()
	if(location.timeZone) now.timeZone = location.timeZone
	sendEvent(descriptionText: "Requested time update", displayed: false)
	executeCommand(secure(zwave.timeV1.timeReport(
			hourLocalTime: now.get(Calendar.HOUR_OF_DAY),
			minuteLocalTime: now.get(Calendar.MINUTE),
			secondLocalTime: now.get(Calendar.SECOND)))
 * Responsible for parsing BasicSet command
 * @param cmd: The BasicSet command to be parsed
def zwaveEvent(hubitat.zwave.commands.basicv1.BasicSet cmd) {
	log.trace "[DTH] Executing 'zwaveEvent(hubitat.zwave.commands.basicv1.BasicSet)' with cmd = $cmd"
	// DEPRECATED: The old Schlage locks use group 1 for basic control - we don't want that, so unsubscribe from group 1
	sendEvent(name: "lock", value: cmd.value ? "unlocked" : "locked")
	def cmds = [
			zwave.associationV1.associationRemove(groupingIdentifier:1, nodeId:zwaveHubNodeId).format(),
			"delay 1200",
			zwave.associationV1.associationGet(groupingIdentifier:2).format()
 * Responsible for parsing BatteryReport command
 * @param cmd: The BatteryReport command to be parsed
def zwaveEvent(hubitat.zwave.commands.batteryv1.BatteryReport cmd) {
	log.trace "[DTH] Executing 'zwaveEvent(hubitat.zwave.commands.batteryv1.BatteryReport)' with cmd = $cmd"
	def map = [ name: "battery", unit: "%" ]
	if (cmd.batteryLevel == 0xFF) {
		map.value = 1
		map.descriptionText = "Has a low battery"
	} else {
		map.value = cmd.batteryLevel
		map.descriptionText = "Battery is at ${cmd.batteryLevel}%"
	state.lastbatt = now()
	sendEvent(map)
 * Responsible for parsing ManufacturerSpecificReport command
 * @param cmd: The ManufacturerSpecificReport command to be parsed
def zwaveEvent(hubitat.zwave.commands.manufacturerspecificv2.ManufacturerSpecificReport cmd) {
	log.trace "[DTH] Executing 'zwaveEvent(hubitat.zwave.commands.manufacturerspecificv2.ManufacturerSpecificReport)' with cmd = $cmd"
	def msr = String.format("%04X-%04X-%04X", cmd.manufacturerId, cmd.productTypeId, cmd.productId)
	updateDataValue("MSR", msr)
	sendEvent(descriptionText: "MSR: $msr", isStateChange: false)
 * Responsible for parsing VersionReport command
 * @param cmd: The VersionReport command to be parsed
def zwaveEvent(hubitat.zwave.commands.versionv1.VersionReport cmd) {
	log.trace "[DTH] Executing 'zwaveEvent(hubitat.zwave.commands.versionv1.VersionReport)' with cmd = $cmd"
	def fw = "${cmd.applicationVersion}.${cmd.applicationSubVersion}"
	updateDataValue("fw", fw)
	if (getDataValue("MSR") == "003B-6341-5044") {
		updateDataValue("ver", "${cmd.applicationVersion >> 4}.${cmd.applicationVersion & 0xF}")
	def text = "${device.displayName}: firmware version: $fw, Z-Wave version: ${cmd.zWaveProtocolVersion}.${cmd.zWaveProtocolSubVersion}"
	sendEvent(descriptionText: text, isStateChange: false)
 * Responsible for parsing ApplicationBusy command
 * @param cmd: The ApplicationBusy command to be parsed
def zwaveEvent(hubitat.zwave.commands.applicationstatusv1.ApplicationBusy cmd) {
	log.trace "[DTH] Executing 'zwaveEvent(hubitat.zwave.commands.applicationstatusv1.ApplicationBusy)' with cmd = $cmd"
	def msg = cmd.status == 0 ? "try again later" :
			cmd.status == 1 ? "try again in ${cmd.waitTime} seconds" :
					cmd.status == 2 ? "request queued" : "sorry"
	sendEvent(displayed: true, descriptionText: "Is busy, $msg")
 * Responsible for parsing ApplicationRejectedRequest command
 * @param cmd: The ApplicationRejectedRequest command to be parsed
def zwaveEvent(hubitat.zwave.commands.applicationstatusv1.ApplicationRejectedRequest cmd) {
	log.trace "[DTH] Executing 'zwaveEvent(hubitat.zwave.commands.applicationstatusv1.ApplicationRejectedRequest)' with cmd = $cmd"
	sendEvent(displayed: true, descriptionText: "Rejected the last request")
def zwaveEvent(hubitat.zwave.commands.notificationv3.NotificationReport cmd) {
	log.trace "[DTH] Executing 'zwaveEvent(hubitat.zwave.commands.notificationv3.NotificationReport' with cmd = $cmd"
    // is this v1AlarmType = 0x2b  (DoorState/DoorSense)
    if (cmd.v1AlarmType == 43) {
        // what is the state of DoorSense
        log.trace "got v1AlarmType = 43"
        switch (cmd.v1AlarmLevel) {
                log.trace "got v1AlarmLevel = 0  (Door Open)"
                sendEvent(name: "DoorSense", value: "open", isStateChange: true)
                break;
                log.trace "got v1AlarmLevel = 1  (Door Closed)"
                sendEvent(name: "DoorSense", value: "closed", isStateChange: true)
                break;
                log.trace "got v1AlarmLevel = 2  (Door Propped)"
                sendEvent(name: "DoorSense", value: "Propped", isStateChange: true)
                break;
            default:
                log.trace "NotificationReport Error (Received non supported v1AlarmLevel from lock)"
                break;
def zwaveEvent(hubitat.zwave.commands.alarmv1.AlarmReport cmd) {
	log.trace "[DTH] Executing 'zwaveEvent(hubitat.zwave.commands.alarmv1.AlarmReport cmd)' with cmd = $cmd"
    sendEvent(displayed: false, descriptionText: "$cmd")
 * Responsible for parsing zwave command
 * @param cmd: The zwave command to be parsed
def zwaveEvent(hubitat.zwave.Command cmd) {
//    log.debug "***********************************************************************************"
	log.trace "[DTH] Executing 'zwaveEvent(hubitat.zwave.Command)' with cmd = $cmd"
 * Executes lock and then check command with a delay on a lock
def lockAndCheck(doorLockMode) {
	def cmds = secureSequence([
			zwave.doorLockV1.doorLockOperationSet(doorLockMode: doorLockMode),
	], 4200)
 * Executes lock command on a lock
def lock() {
	log.trace "[DTH] Executing lock() for device ${device.displayName}"
	lockAndCheck(DoorLockOperationSet.DOOR_LOCK_MODE_DOOR_SECURED)
 * Executes unlock command on a lock
def unlock() {
	log.trace "[DTH] Executing unlock() for device ${device.displayName}"
	lockAndCheck(DoorLockOperationSet.DOOR_LOCK_MODE_DOOR_UNSECURED)
 * Executes unlock with timeout command on a lock
def unlockWithTimeout() {
	log.trace "[DTH] Executing unlockWithTimeout() for device ${device.displayName}"
	lockAndCheck(DoorLockOperationSet.DOOR_LOCK_MODE_DOOR_UNSECURED_WITH_TIMEOUT)
 * PING is used by Device-Watch in attempt to reach the Device
def ping() {
	log.trace "[DTH] Executing ping() for device ${device.displayName}"
	runIn(30, followupStateCheck)
 * Checks the door lock state. Also, schedules checking of door lock state every one hour.
def followupStateCheck() {
	runEvery1Hour(stateCheck)
	stateCheck()
def stateCheck() {
	sendHubCommand(new hubitat.device.HubAction(secure(zwave.doorLockV1.doorLockOperationGet())))
 * Called when the user taps on the refresh button
def refresh() {
	log.trace "[DTH] Executing refresh() for device ${device.displayName}"
	def cmds = secureSequence([zwave.doorLockV1.doorLockOperationGet(), zwave.batteryV1.batteryGet()])
	if (!state.associationQuery) {
		cmds << "delay 4200"
		cmds << zwave.associationV1.associationGet(groupingIdentifier:2).format()  // old Schlage locks use group 2 and don't secure the Association CC
		state.associationQuery = now()
	} else if (now() - state.associationQuery.toLong() > 9000) {
		cmds << "delay 6000"
		cmds << zwave.associationV1.associationSet(groupingIdentifier:2, nodeId:zwaveHubNodeId).format()
 * Called by the Smart Things platform in case Polling capability is added to the device type
def poll() {
	log.trace "[DTH] Executing poll() for device ${device.displayName}"
	def cmds = []
	// Only check lock state if it changed recently or we haven't had an update in an hour
	def latest = device.currentState("lock")?.date?.time
	if (!latest || !secondsPast(latest, 6 * 60) || secondsPast(state.lastPoll, 55 * 60)) {
		log.trace "poll is sending doorLockOperationGet"
		state.lastPoll = now()
	} else if (!state.lastbatt || now() - state.lastbatt > 53*60*60*1000) {
		state.lastbatt = now()  //inside-214
	if (state.assoc != zwaveHubNodeId && secondsPast(state.associationQuery, 19 * 60)) {
	} else {
		// Only check lock state once per hour
		if (secondsPast(state.lastPoll, 55 * 60)) {
		} else if (!state.MSR) {
		} else if (!state.fw) {
		} else if (!device.currentValue("maxCodes")) {
			state.pollCode = 1
		} else if (state.pollCode && state.pollCode <= state.codes) {
			cmds << requestCode(state.pollCode)
	if (cmds) {
		log.debug "poll is sending ${cmds.inspect()}"
	} else {
		// workaround to keep polling from stopping due to lack of activity
		sendEvent(descriptionText: "skipping poll", isStateChange: true, displayed: false)
		return null
 * Returns the command for user code get
 * @param codeID: The code slot number
 * @return The command for user code get
def requestCode(codeID) {
	executeCommand(secure(zwave.userCodeV1.userCodeGet(userIdentifier: codeID)))
 * API endpoint for server smart app to populate the attributes. Called only when the attributes are not populated.
 * @return The command(s) fired for reading attributes
def reloadAllCodes() {
	log.trace "[DTH] Executing 'reloadAllCodes()' by ${device.displayName}"
	sendEvent(name: "scanCodes", value: "Scanning", descriptionText: "Code scan in progress", displayed: false)
	state.checkCode = state.checkCode ?: 1
	def cmds = []
	// Not calling validateAttributes() here because userNumberGet command will be added twice
	if (!state.codes) {
		// BUG: There might be a bug where Schlage does not return the below number of codes
		executeCommand(secure(zwave.userCodeV1.usersNumberGet()))
	} else {
		sendEvent(name: "maxCodes", value: state.codes, displayed: false)
		cmds << requestCode(state.checkCode)
	if(cmds.size() > 1) {
		cmds = delayBetween(cmds, 4200)
def reloadCodes(positions) {
	log.trace("Executing 'reloadCodes' by ${device.displayName} with $positions")
	if (state.codeReloadList?.size() > 0 || state.checkCode != null) {
		log.warn("Code reload already in progress")
		return
	def positionList = []
	def validPositions = (1..device.currentValue("maxCodes"))
	if (positions == "ALL") {
		positionList = validPositions
	} else {
		def textList = positions.tokenize(",")
		textList.each { v ->
			p = v.trim().tokenize("-")
			if (p.size() == 1) {
				positionList.add(p[0].toInteger())
			} else if (p.size() == 2) {
				(p[0].toInteger()..p[1].toInteger()).each { positionList.add(it.toInteger()) }
		validPositions = validPositions.toSet()
		positionList = positionList.toSet()
		positionList = positionList.intersect(validPositions)
		positionList = positionList.toList().sort()
	if (positionList.size() > 0) {
		sendEvent(name: "reloadCodes", value: "reloading began", descriptionText: "Reloading codes beginning with positions: $positions" )
		state.codeReloadList = (new groovy.json.JsonOutput()).toJson(positionList)
		state.codeReloadList = positionList
		state.checkCode = positionList.first()
		log.trace("Beginning code reload for positions: $positionList")
	} else {
		log.warn("Invalid code positions: $positions")
def getCodes() {
    return loadLockCodes()
 * API endpoint for setting the user code length on a lock. This is specific to Schlage locks.
 * @param length: The user code length
 * @returns The command fired for writing the code length attribute
def setCodeLength(length) {
	return null
 * API endpoint for setting a user code on a lock
 * @param code: The code PIN
 * @param codeName: The name of the code
 * @returns cmds: The commands fired for creation and checking of a lock code
def setCode(codePosition, pin, codeName = null) {
    log.trace("calling set code")
//    log.debug "code = " + code
//    log.debug "!code = " + !code
	if (!pin) {
		log.trace "[DTH] Executing 'nameSlot()' by ${this.device.displayName}"
		// update later Joe
		//nameSlot(codeID, codeName)
		return
	log.trace "[DTH] Executing 'setCode()' by ${this.device.displayName} with codeid $codePosition, code $pin, name $codeName"
	if (addCodeToLockCodes(codePosition, pin, codeName)) {
		executeCommand(secure(zwave.userCodeV1.userCodeSet(userIdentifier:codePosition, userIdStatus:1, userCode:pin)))
	} else {
		log.warn "[DTH] setCode: Invalid pin: $pin"
private def isPinValid(pin) {
	if (pin instanceof List) {
		pin = pin.collect{ it as Character }.join()
	if (pin instanceof String) {
		// trim pin
		pin = pin.trim()
	} else {
		// pin was not a string
		pin = pin.toString()
	if (!(pin =~ /^\d+$/)) {
		// pin was not only numeric digits
		return false
	return pin
def boolean addCodeToLockCodes(codePosition, pin, codeName=null, validated=false) {
	if (!codeName) { codeName = "Code $codePosition" }
	pin = isPinValid(pin)
	if (!pin) { return false }
	lockCodes[codePosition.toString()] = ["name": codeName, "code": pin.toString(), "status": "contingent"]
	return true
def validateLockCode(codePosition, validated=true) {
	lockCades = loadLockCodes()
	lockCodes[codePosition.toString()].status = "active"
 * Validates attributes and if attributes are not populated, adds the command maps to list of commands
 * @return List of commands or empty list
def validateAttributes() {
	if(!device.currentValue("maxCodes")) {
	log.trace "validateAttributes returning commands list: " + cmds
 * API endpoint for deleting a user code on a lock
 * @returns cmds: The command fired for deletion of a lock code
def deleteCode(codePosition) {
	log.trace "[DTH] Executing 'deleteCode()' by ${this.device.displayName}"
	// AlarmReport when a code is deleted manually on the lock
	def cmd = secureSequence([
			zwave.userCodeV1.userCodeSet(userIdentifier:codePosition, userIdStatus:0),
			zwave.userCodeV1.userCodeGet(userIdentifier:codePosition)
	], 4200)
	executeCommands(cmd)
 * Encapsulates a command
 * @param cmd: The command to be encapsulated
 * @returns ret: The encapsulated command
private secure(hubitat.zwave.Command cmd) {
//	zwave.securityV1.securityMessageEncapsulation().encapsulate(cmd).format()
    zwaveSecureEncap(cmd)
 * Encapsulates list of command and adds a delay
 * @param commands: The list of command to be encapsulated
 * @param delay: The delay between commands
 * @returns The encapsulated commands
private secureSequence(commands, delay=4200) {
	delayBetween(commands.collect{ secure(it) }, delay)
 * Sends the queued commands
private executeCommands(commands) {
	for (cmd in commands) {
		executeCommand(cmd)
 * Sends the command to the hub
private executeCommand(command, callback=null) {
	def hubAction = new hubitat.device.HubAction(command, hubitat.device.Protocol.ZWAVE)
	sendHubCommand(hubAction)
 * Checks if the time elapsed from the provided timestamp is greater than the number of senconds provided
 * @param timestamp: The timestamp
 * @param seconds: The number of seconds
 * @returns true if elapsed time is greater than number of seconds provided, else false
private Boolean secondsPast(timestamp, seconds) {
	if (!(timestamp instanceof Number)) {
		if (timestamp instanceof Date) {
			timestamp = timestamp.time
		} else if ((timestamp instanceof String) && timestamp.isNumber()) {
			timestamp = timestamp.toLong()
		} else {
			return true
	return (now() - timestamp) > (seconds * 1000)
 * Reads the code name from the 'lockCodes' map
 * @param lockCodes: map with lock code names
 * @returns The code name
private String getCodeName(codeID) {
	if (isMasterCode(codeID)) {
		return "Master Code"
	return lockCodes[codeID.toString()].name
 * Check if a user code is present in the 'lockCodes' map
 * @returns true if code is present, else false
private Boolean isCodeSet(codeID) {
	// BUG: Needed to add loadLockCodes to resolve null pointer when using schlage?
	lockCodes[codeID.toString()] ? true : false
 * Reads the 'lockCodes' attribute and parses the same
 * @returns Map: The lockCodes map
private Map loadLockCodes() {
    def stuff = device.currentValue("lockCodes")
    def stuff2 = decrypt(stuff)?:stuff
	parseJson(stuff2 ?: "{}") ?: [:]
 * Populates the 'lockCodes' attribute by calling create event
 * @param lockCodes The user codes in a lock
private def sendLockCodesEvent(lockCodes) {
	sendEvent(name: "lockCodes", value: (new groovy.json.JsonOutput()).toJson(lockCodes), displayed: false,
			descriptionText: "'lockCodes' attribute updated")
 * Utility function to figure out if code id pertains to master code or not
 * @param codeID - The slot number in which code is set
 * @return - true if slot is for master code, false otherwise
private boolean isMasterCode(codeID) {
	if(codeID instanceof String) {
		codeID = codeID.toInteger()
	(codeID == 0) ? true : false
 * Generic function for reading code Slot ID from AlarmReport command
 * @return user code slot id
def readCodeSlotId(hubitat.zwave.commands.alarmv2.AlarmReport cmd) {
	if(cmd.numberOfEventParameters == 1) {
		return cmd.eventParameter[0]
	} else if(cmd.numberOfEventParameters >= 3) {
		return cmd.eventParameter[2]
	return cmd.alarmLevel
def logsOff(){
    log.warn "debug logging disabled..."
