Added Switchbot Meter Pro with CO2, Temp, Humidity sensors
Just added relatively new Switchbot Meter Pro to my sensors collection. The device is nice looking, battery/usb powered, has CO2, Temp and Humidity sensors with big easy redable LCD screen. Now this toy is on sale for around $60. The communication is Bluetooth so it cannot be directly connected to HE. But it was instantly picked up by Home Assistant (HA already was in place). CO2, Temp and Humidity attributes are available to HE via HADB and ready to be used in automations.
You may be able to go local with this link. I moved my SB Hub 2 over so I no longer have to send China any data. Support is limited but it covered my Hub internals and my blinds.
It could be not quite clear from my post but I don't have Switchbot hub at all.
All my Switchbot devices (5 curtain-rod, 2-switchbot and now Meter Pro sensor) from day #1 integrated with HE 100% locally via HA<-->HADB. This works perfectly fine.
Yes, I am using Matter Advanced Bridge for few Matter Devices (3 MS600 sensors and 1 Tapo Dimmer). Frankly at this time I am trying to avoid Matter Devices.
Ah, thought the Meter Pro might be a SB hub.
Yes, I avoid Matter due to its convoluted nature.
I only did it to get off of my SB Hub Mini and on to the Hub2 so I could have local control.
