Added Echo Dot, not showing available in Hubitat
I purchased a 4th Echo device after having 3 on my network for some time. For some reason it does not show up in Hubitat. My other 3 work perfect.
Is there a discovery or setting I need to change in order to get Hubitat to recognize it?
Hubitat does not natively integrate in this direction (Alexa device to Hubitat), only the other way around (Hubitat devices exposed to Alexa). In the latter case, there is nothing special to do, as the selected Hubitat devices will be exposed to any Alexa device on the same Amazon account.
If your situation is the former, you must be using a custom app (Echo Speaks, maybe?). Posting more information about whatever your setup is in this regard will be helpful.
I'm using Amazon TTS Manager. I figured it out, had to add it there first.
