As of platform version 2.2.6, Hubitat allows importing org.apache.commons.lang3.time.DateUtils. You can find documentation for it here: DateUtils (Apache Commons Lang 3.12.0 API). It provides lots of "shortcut" methods that can do things that sound like what you describe.
That being said, I haven't made use of it yet, and whenever I need to work with dates I pretty much do what it sounds like you do: convert to Unix time, then work with the resulting long and standard math to get what I need. (So I'm a bad person to ask if it actually makes things easier...)
You could probably do import groovy.time.TimeCategory and then just do use (TimeCategory). but all that saves is typing--no difference in runtime behavior. I wasn't sure if that was on the allowed list of classes, but it looks like it is. Glad you figured something out!
not sure if its a good topic for this. I'd like to create an easy "Sunrise Alarm" and for that I need to start rising light 30 minutes before the specified time.
e.g. I set wakeup time to 5:30, I'd like to set a rule which starts rising light from 0 to 90% between 5:00 - 5:30 For this I need to subtract 30 minutes from the wakeup time to make life easy.
Is there a way to do variable math on datetime?
If there's no way, I will just set the time 30 min before but that way anyone can do
the way I'm thinking to do this:
sunrise-alarm-time = 5:30
sunrise-alarm-start-raise-time = sunrise-alarm-time - 0:30
when switch sunrise alarm turned on and time is sunrise-alarm-start-time , start rising bulb X from 0 rise time 30 min
