Add humidity offset to built-in generic ZigBee temperature and humidity driver
Please add humidity offset or reference to the built-in generic ZigBee temperature and humidity driver
I would try this driver from kkossev instead, I believe it will work for most devices that work with the generic Zigbee driver. It will give you the humidity offset, as well as some advanced configs if your device supports them, like how often it reports. It supports several specific device types in preferences, and it can auto detect your device.
It may be worth a shot to see if it works.
Tagging @mike.maxwell from Hubitat.
I would also like to see this feature added as I have recently started to pay much more attention to humidity levels in my house and my crawlspace.
I agree, it would be a good add and it really should already be available in the built-in generic driver, but it is not like you don't have other options with community drivers.
I use that driver now. Offsets should be integrated into the built-in drivers.
