Hi all,
I want to install a light switch to my hubitat hub. The location of the switch is going to be too far away to connect directly to the hub, but should work over the mesh network that I have created between the hub and the switch location. However, when first adding to switch, do I need to install it in a location right by the hub, or will it be able to find it through the mesh network?
