Tring to make a button on the dash board to "push" the POLL command.
So I can "refresh" the data right away. So new at this I can not find away.
all I see listed is the attributes is the stuff on the right. The "poll" button
under heading commands .. does "refresh" when pushed.
Any help would be great thanks.,
The commands are not directly available to add to a dashboard. What you can do is create a virtual button device and then create a button controller rule to run a custom action (the poll command) when the button is pressed. The button device can then be added to the dashboard.
Worked thanks
