I've only had my HE a few weeks now but already noticed a few occasions when rules are not getting executed. Eg, Rule: hot-water on at XX time, wait 30mins then hot-water off.
the last part of the rule (hot water OFF) never happened on a couple of occasions. It didnt even appear in the logs (so this is not a case of the z-wave command not getting received which i have also experienced, RF Interference, etc, but thats a more complex issue)
now considering adding extra code, which shouldnt be needed, in order to make sure the task gets fulfillled, ie, repeating the last command twice:
i could understand if maybe i was doing some code updates or accessing the HE during the time the code was due to occur which upset the system but this was not the case.
BTW still running firmware 2.3.2.141
Aware of that. As mentioned, i think disabling and re-enabling logs must have cleared past history.
I can see everything related that has occurred since doing so.
That is not how the feature works. Think of logging as "streaming events". If you have the logs enabled, they are posted in the Logs (past Logs). If you turn off logging they stop being posted. The only time logs are removed, is if the past log file is full. In that case, new logs from any app or device overwrite oldest logs....
