Access to community-dev.hubitat.com
A lot of my duckduckgo searches point to promising results on https://community-dev.hubitat.com, but neither Firefox nor Edge are able to connect. How do I get access to view?
I would guess that was a temporary site used to test a community forum upgrade, that they did not block from search crawlers. Anything found linking to that, the same stuff should be on here.
I also use DDG and have the same issue. I modify the address removing "-dev" so it's https://community.hubitat.com
Is there any reason you don't use the search option within the Community, at least when wanting to search for topics here? I can understand wanting to search more broadly and using a search engine that supports that, but if there is a more targeted and appropriate platform....?
Fair question. Some of my searches were general home automation questions, and sometimes I couldn't find what I was looking for with the Hubitat search.
Thanks, I should have thought of that.
