Access to Amazon Alexa Devices from Hubitat
I've been using the Amazon Echo Skill to access Hubitat devices from Alexa for a few years now, but I now need to access the temperature and motion sensors built into the latest gen Echo and Dot devices. Does such a driver or app exist to allow Hubitat to access Alexa devices?
As far as I know, there’s no driver available to get this information. It might be possible to setup a routine to turn on/off a switch/sensor device that is shared from Hubitat to Alexa when motion is detected or not.
Have not tried this with built in motion sensors, but I use it for my doorbell that integrates to Alexa and it works to get the status over to HE.
Getting the temperature from Alexa over to HE is not possible I am afraid. There is no way to mirror the numerical info into a virtual device. The best you could do is setup a virtual switch to turn on / off at preset temps.
I wonder if there would be some way to set a dimmer to a dimming level equivalent to the temperature…?
The Echo Speaks community app creates devices in Hubitat for the echos and they have lots of attributes. I don’t have any of the new ones with temp and humidity so I don’t know if those attributes are available on those echos but here is all the info I can get of my older echos
Current States
  • alarmVolume : 30
  • alexaPlaylists : {}
  • alexaWakeWord : ALEXA
  • audioTrackData : {}
  • btDeviceConnected : None Connected
  • btDevicesPaired : {"names":[]}
  • currentAlbum : Idle
  • currentStation : Idle
  • deviceFamily : ECHO
  • deviceIcon :
  • deviceSerial :G0911M06922513SM
  • deviceStatus :stopped_echo_dot_gen3
  • deviceStyle : Echo Dot (Gen3)
  • deviceType : A1RABVCI4QCIKC
  • doNotDisturb : false
  • firmwareVer : 8960323972
  • followUpMode : false
  • lastAnnouncement : NA
  • lastSpeakCmd : NA
  • lastSpokenToTime :1632271144049
  • lastUpdated : May 4, 2023 - 7:41:43 AM
  • lastVoiceActivity : NA
  • level : 30
  • mediaSource : NA
  • mute : unmuted
  • onlineStatus : online
  • permissions : [reminders, volumeControl, tuneInRadio, TTS, doNotDisturb, isMultiroomMember, microphone, isEchoDevice, flashBriefing, followUpMode, amazonMusic, spotify, alarms, bluetoothControl, announce, iHeartRadio, pandoraRadio, guardSupported, mediaPlayer, wakeWord]
  • phraseSpoken : NA
  • status : stopped
  • supportedMusic : TuneIn, My Library, Amazon Music, iHeartRadio
  • trackData : {}
  • trackDescription : NA
  • trackImage : NA
  • trackImageHtml :
  • volume : 30
  • wakeWords :ALEXA,AMAZON,COMPUTER,ECHO,HEY_SAMUEL,HEY_SANTA,ZIGGY
  • wasLastSpokenToDevice : false
Thanks to all of you for the great suggestions. I already use a virtual switch to pass info between Alexa and HE so I know that should work for motion detection. I'll let you know the results after I get a chance to try the recommended approaches for temperature.
